Gear box
3 replies to this topic
  • h20mn
Posted June 01, 2011 - 01:21 PM
Has anybody swaped out a 06 wr gear box into a 07 yz ? If so did you have to change out the cams or leave everything stock.
Posted June 01, 2011 - 01:31 PM
That won't work. The '06 WR is an Gen1 450, while the '07 YZF as a Gen2. The trans in the later models is about 12mm wider overall.
However, the wide ratio trans from an '07 or later WR450 WILL fit, and can be installed using the YZF cam, forks and output shaft.
http://www.thumperta...ad.php?t=464212
Factoid: If you use the first 3 gears from a YZF, and the 4th and 5th from the WR, you end up with a first 4 gears just like the '03 '05 4 speed, plus the 5th gear on top.
  • brentn
Posted June 01, 2011 - 08:27 PM
You mentioned this before, what is 4th gear like on the 03? Just inbetween 4/5 on the later models?
I think I want to try this to get a taller 4/5 for the fire roads I frequent... Either that or just a 5th.
Posted June 01, 2011 - 09:11 PM
Here they are:
'06-'11
YZ450...03YZF....'07WR....Hybrid*
1.929....1.929....2.416.....1.929
1.533....1.563....1.733.....1.533
1.278....1.278....1.312.....1.278
1.091....1.050....1.050.....1.050
0.952................0.840.....0.840
*'06-'11 YZ450 1,2,3 w/'07+ WR450 4-5
  • 10 replies
  • 5 replies
  • Hot  28 replies
  • Hot  38 replies
