Will a BBR TTR50 fork kit fit on a TTR90?
Same question for the swingarm.
Thanks
Ttr90
Started by
Lorre79
, Jun 01 2011 12:40 AM
1 reply to this topic
Posted 10 June 2012 - 03:46 PM
did you ever work this out? I just put a TTR90 swing arm on a 50 - it fit ok - had to weld a piece for the brake drum to mount and spacers where the shock mounted. so they are pretty compatible. I wanted a longer swing arm on the 50 - not sure why you would want a shorter one on a 90 unless you are looking at after market swingarm. the 90 was about an inch longer than the 50's.
