We're re-jetting!
We will be performing site maintenance today (May 25th). You make experience a temporary slowdown during this time. Don't worry, we'll be back at full speed in no time.
KLX140 won't start
12 replies to this topic
  • amtzzero
Posted May 31, 2011 - 07:43 PM
My wife's klx140 will not start. I can hear the starter motor and the engine does WANT to start but it just won't. I washed it, and after I washed it, I went to start it to let the water evaporate off the engine. I usually use the throttle when it's cold to start it but when I let go of the throttle, it turned off. (That's normal when it's cold) but this time, it didn't want to start up anymore after that. The battery is fine and so is the starter. The spark plug looks okay too. I checked the air filter, and everything seemed okay. Does anyone have any idea what it could be? Carb, fuel petcock, fuel line, valves? What could it be? Any help will be greatly appreciated! Thanks!
  • Monika
Posted June 01, 2011 - 04:53 AM
Did you use a pressure washer when you washed it? Ours did the same thing after a pressure washing. The next day it started up fine, not sure what the problem was. I was happy because it finally convined my husband that pressure washing is not the best way to wash the bikes (even tho I had told him that before).
  • amtzzero
Posted June 01, 2011 - 06:44 AM
No, I don't have a pressure washer but the hose DOES have a nozzle where you can adjust the stream and amount of water that comes out. I had it at full blast. I REALLY hope it's something simple like that. When you washed yours, how many times did you try to start it afterwards?
  • amtzzero
Posted June 01, 2011 - 09:57 AM
When you say that yours did the same thing, could you also hear the starter motor and everything? Did you try to start it a lot of times?
  • 4strokeridertt
Posted June 01, 2011 - 02:09 PM
Sounds like maybe you got the airfilter all wet and it may have sucked some moisture into the carb.
Check the filter to be sure it is dry, then check the pilot jet to be sure it is not clogged.
  • amtzzero
Posted June 01, 2011 - 10:24 PM
Yeah, I'm having a guy look at the bike tomorrow. Today it started up, but turned off again after 30 seconds?:smirk:
  • Monika
Posted June 02, 2011 - 01:30 PM
Yes, it was turning over, it just wasnt firing it up. Tried a whole bunch of times, till the battery started sounding weak. Eventually it did fire up, but it ran rough for a little while, then cleared up.
  • amtzzero
Posted June 02, 2011 - 03:17 PM
It was the carb. I had a guy come clean it for me and now it runs fine. Thanks everybody!
  • jimbo74
Posted October 27, 2011 - 02:16 AM
My missus has a klx140 too and it is terrible to start. I need to make sure the fuel is super fresh and I bleed it each time I stop it. Run it completely dry. However, now I have a battery problem. The battery is fine (had it tested) but it seems to leak voltage somewhere and goes flat in no time. Has anyone had a an amperage/voltage leak issue in their 2011 KLX 140?
  • 4strokeridertt
Posted October 27, 2011 - 10:07 AM
you should rejet it if you have not done it yet. That should help it start better.
Are you switching off the button when your not riding it? Leaving it on will cause the battery to run down.
  • jimbo74
Posted October 27, 2011 - 04:33 PM
Yes, i do all that. I reckon it is an earth leak somewhere..
  • 4strokeridertt
Posted October 28, 2011 - 10:05 AM
Follow all the wires and clean ALL the connections. A bad ground will cause the battery to appear down on amperage.
  • WTA
Posted January 09, 2012 - 03:45 AM
Brush the spark plug and drain the carb. Then choke it ...will start sure ! I have 7 klx 140L
Edited by WTA, January 09, 2012 - 03:46 AM.
wrong
