WR rear wheel size and tire suggestions
6 replies to this topic
  • wick246
Posted May 30, 2011 - 04:43 PM
I bought my 2001 WR426 with a Dunlop D750 120 80 19 rear tire. It's time to change it and I don't have any idea what to go with this time. I have read that the 18" wheel / tires give more sidewall to prevent pinch flats - is there anything else I'm missing out on by having a 19" rear? Is it critical that I use an 18" rear?
The front tire is a 21" d739 and is in decent shape, should I find a D739 for the rear as well? I ride mostly mountain trails with rocks, packed dirt and some sand.
Edited by wick246, May 30, 2011 - 04:44 PM.
  • Just_a_trail_rider
Posted May 30, 2011 - 04:47 PM
I love the 739 for the rear in the desert. I run an 18 inch 120 though.
regarding 18 or 19.... I don't think you'll be any more prone to flats, but you will be more prone to dent the rim.
If I were racing (a lot), I'd want a 19 and not an 18. But, if you are happy with the way that it performs, then wait until you destroy the rear rim before you swap it out.
  • MaxPower
Posted May 30, 2011 - 08:12 PM
[COLOR="DarkGreen"]Ill bet 99% of people could get on a bike and not guess if they had a 18 or 19 on the rear
  • wick246
Posted May 30, 2011 - 08:44 PM
Cool, I'll see if I can get it off this week and have a 739 mounted. Been way too long since I've been out on the trails. :smirk:
  • MANIAC998
Posted May 31, 2011 - 04:12 AM
While racing Harescrambles, I got flats while using the 19" on my YZF. When I re-laced it to a 18", I never got another flat. Your results may vary, as I'm a hammerhead when it comes to rock gardens. Maniac
  • Salinas_THumper
Posted June 04, 2011 - 01:28 PM
i use the stocker rims and love Kenda tires. I ride similar conditions.
  • Strattos
Posted June 05, 2011 - 10:36 PM
In terms of the width issue at the rear, I've been told that a 110 width helps turning and staying/getting into ruts etc, while the wider 120 is better for desert racing - just what I've been told.
I've tried both and for my ability - punter - I couldn't tell the difference.
