Float bowl removal 2007 WR450f
13 replies to this topic
  • coxey2
Posted May 30, 2011 - 04:32 PM
Thanks to some experts here; I now have my jetting worked out. Just wondering if the float bowl can be removed without taking the carb off. Its the 07 model with the chunky aluminum frame??
  • William1
Posted May 30, 2011 - 04:58 PM
It can be removed on the bike, with the right tools.
For the experienced wrench, it is worth the time saving. If you are not 100% sure of your ability, tend to have bad luck dropping small parts that get lost forever in the bowels of the garage, then pull the carb. I am 100% confident in my ability but the invisible gremlins force me to do the carb on the bench when woirking on an alloy framed bike. Once you have done it a dozen times, the carb removal and install takes less than thirty minutes. I spend more time than that looking for my marbles.
  • SXP
Posted May 30, 2011 - 05:27 PM
William - Isn't the starter motor in the front of the engine on the Al framed 250s? You have a lot more room to work with under the carb with the 250s as you don't have the starter motor to deal with. On the 450s it's pretty much directly under the carb taking away precious access/maneuvering room. I'd love for someone (preferably an owner of an 07+ 450 who has experience working with these suckers) to show me how to remove and re-install the float bowl with the carb in place.
  • JDLowrance
Posted May 30, 2011 - 08:47 PM
Pull the carb. This will allow you to clean the acc pump assembly as well.
  • mikewrf18
Posted May 30, 2011 - 09:48 PM
I have an 07' WR450F. For me it is not worth the frustration to try and mess with taking the float off or removing jets with the carb on the bike. I don't want to risk stripping threads and loosing small parts. I've found that removing the carb takes very little time after doing it multiple times, and I have it down to a science now. I know that some guys on here are pretty good at messing with jets and removing the float bowl with the carb on the bike though. I believe it takes some enginuity by making some special tools and such to get into those tight spaces.
  • dgcars
Posted May 31, 2011 - 01:16 AM
Well....like I said in the OP's previous thread, there is no need to pull the carb to take off the float bowl.
Agreed, mike & william1, it isn't easy without the right tools, just the way I like to do it.
I use a 'Zebra' ultra fine ratchet with a 3mm allen wrench for this purpose. It would probably be less hassle to pull the carb without it.
PLEASE...SXP & JDL - We all have our own opinions. I'll respect yours....
I'll post a pic when I get back to my shop, for anyone who is interested in my 'tool'. :smirk::prof::smirk:
  • dgcars
Posted May 31, 2011 - 02:35 AM
And this is it.....Posted Image
  • mikewrf18
Posted May 31, 2011 - 02:44 AM
Nice Tool! :smirk:
I may have to take a crack at doing it with the carb on again at some point. I have really bad luck with loosing small parts sometimes though, then I spend the next hour fishing around for them! :prof: :smirk:
  • dgcars
Posted May 31, 2011 - 02:49 AM
^^^Thanks. I've had that a few years, but as far as I know - still available from Wurth.
  • William1
Posted May 31, 2011 - 05:29 AM
I use the Motion Pro 90 degree driver. But on bikes with limited clearance or days when my vision is poor or the shop over run with gremlins, I pull the carb (well, I make my assistants do it).
  • SXP
Posted May 31, 2011 - 06:19 AM
Oh, I respect your opinion. But (and this is to William too), have either of you done this on an 07+ WR450, or are you just shooting from the hip based on your ownership experience with a 250. Like it or not, they are different bikes. If you tell me you have successfully done it on a 450 in less time and with less aggravation then it would take to remove the carb using the "long way" , then I obviously have something to learn. My beef is with generalizations that what worked on your 250 will work on the 450, thats all.
Edited by SXP, May 31, 2011 - 07:12 AM.
  • William1
Posted May 31, 2011 - 07:48 AM
Not today. One last week and few earlier in May. Out of those, One I did on the bike. Near new bike, everything clean and in good condition. On the nasty ones with plier marks, I pull the carb.
  • dgcars
Posted May 31, 2011 - 08:05 AM
Well...I sold my last '07 450 in 2009. Whether it is either more difficult or more time consuming one way or the other, is kind of a personal thing. What appears a b**** of a job for one person may well be straight forward for another.
On a 450...it'll take me about 30 - 40 mins pulling and replacing the carb. Removing the bowl with it in place and on again about 20 mins.
Agreed...it is a bit easier on a 250 to do in situ, but the method is still the same. Stretch out a cloth underneath the carb (catches the bits that fall) and try it sometime - just for the hell of it. You may or may not like it....but like i have said, thats up to you.
  • SXP
Posted May 31, 2011 - 10:43 AM
I've tried it and gave up. Too aggravating for my patience level, and frankly seemed impossible to me. But, if you guys say you've done it I'll take your word for it:thumbsup:
