what to flush with
what should i flush the engine with after i tap my oil drain hole? just to get the shavings out. thanks in advance!
Nothing. You should grease the tap and work slowly, cutting 2-3 threads, then backing out, cleaning and re-greasing the tap. When you're done, grease a cotton swab and reach past the whole to sweep for chips.
Which drain hole?
Ok sweet thanks! Oh and I know its a little off topic but I was thinking of getting a newer 450f for single track/trails, Would a 450 even be suitable for that tight stuff? I like my 426 but its a little heavy and I would like something a little newer. I am 5'9 142 if that helps. Thanks!
