Pro Circuit 143.5 link arm 2010 / 2011
36 replies to this topic
  • motojase316
Posted May 27, 2011 - 03:44 AM
I have been reading some reviews of the pro circuit 143.5 link arm and decided to give it a run on my 2011 yz450f. Will get out and test it soon.
Is anyone else running this link? And what did you experience? Any changes, better or worse?
  • motojase316
Posted May 27, 2011 - 03:50 AM
  • eazrider
Posted May 27, 2011 - 09:34 AM
I am using a 2007 WR450 link, which, dimensionally, is the same as the PC part. I had to change my sag to less, (130 to 105), slide my forks down (raising the front geometry) fom 10mm to 5mm above the clamp. The result was a bike that feels neutral going into corners, no wiggle, very stable, very "balanced"...:smirk:
  • almostinvincible119
Posted May 27, 2011 - 02:00 PM
Did the same thing. Love the results. My wallet does as well, paid 60 bucks vs. $200 for the PC link
  • motojase316
Posted May 27, 2011 - 03:22 PM
That is awesome, I have not heard about the wr450 link. would have been a good option, the PC link is a little pricey.
  • motojase316
Posted May 27, 2011 - 03:23 PM
Thats good feedback eazrider, they are the exact problems i am hoping to sort out.
  • brentn
Posted May 27, 2011 - 03:42 PM
How much does the link lower the bike when your sitting on it? Does the rear suspension bottom out easier with the link?
  • motojase316
Posted May 27, 2011 - 06:59 PM
It is supposed to lower the rear end around 25mm, but the different rising rate will hold the shock in a different part of the stroke. so it should not bottom out easy. will see the difference when i hit the track.
  • eazrider
Posted May 27, 2011 - 08:34 PM
The WR link lowered my ride height at the seat by exactly 10mm. Changing the length of the link does NOT change other characteristics of the rear suspension, just the height of the rear (and corresponding fork angle)
  • bhoag45
Posted May 28, 2011 - 01:05 AM
I used a YZ250 2 stroke link and it works great
  • brentn
Posted May 28, 2011 - 02:22 PM
My 2010 is just a tad too tall, maybe a link like what you guys are using along with a good sag adjustment might lower it enough?..
thx for the info.
  • geshields
Posted May 29, 2011 - 10:57 AM
I just got a bike from one of the MotoConcepts riders which has a factory GYTR 144.0 link. He said it is more suited for supercross and I may not like it for MX. Would going to the procircuit or wr link with only 0.5mm difference really matter?
Posted May 29, 2011 - 03:56 PM
GE: I had the same thought, but it really does. Just think about what one click on he forks do, or 5mm in the clamps or just 2 or 3mm's of sag...all those small tiny things make a huge difference.
  • hardcore-mx251
Posted May 30, 2011 - 02:47 AM
I see the DLC coated forks in your pics there MJ316, looks like you have put some serious money in your suspension huh!!!
  • gfmoto
Posted May 30, 2011 - 09:38 AM
what year wr link did you use?
Posted May 30, 2011 - 04:35 PM
Hate the 5 character reply limit
  • motojase316
Posted June 01, 2011 - 03:40 AM
Yeah mate, those forks cost me some big dollars so far.
  • occrfmx
Posted June 02, 2011 - 06:46 PM
How do you know what the linkage arm lengths are for different bikes? Would the linkage arm off a 2006 YZ450F be the same as the 2007 WR 450 (143.5)?
  • BBrown626
Posted June 03, 2011 - 03:18 PM
I am using a 2007 WR450 link, which, dimensionally, is the same as the PC part. I had to change my sag to less, (130 to 105), slide my forks down (raising the front geometry) from 10mm to 5mm above the clamp. The result was a bike that feels neutral going into corners, no wiggle, very stable, very "balanced"...:ride:
So if you install a link that lowers your ride height by 25mm and you then decrease your sag by 25mm you are right back where you started. How then does the link help with stability entering a corner? You went from 10mm to 5 up front. Does that account for the perceived improvement?
I could see where the ability to soak up bumps would be affected, but I don't see where the change in the linkage helps with stability.
  • eazrider
Posted June 03, 2011 - 08:09 PM
Beats me, I'm not the smart guy on this subject, I just know it works well...:ride:
  • On January 15, 2017
  • Hot  36 replies
  • 0 replies
  • 10 replies
