I am doing a big wheel conversion on my son's KX 85. I purchased the swingarm, wheels/rims,tires, and rear brake line. Do I need anything else? Will I need to change the linkage or shock or is it the same. Thanks for help
KX 85 Big Wheel conversion
Started by
NSF3537
, May 26 2011 03:36 PM
9 replies to this topic
Posted 27 May 2011 - 04:58 AM
NSF3537 said:
Nobody can help? I know someone has done this.
You'll need this too. It will work with the one from an 85, but it won't work the way it should.
39007-1261 ARM-SUSP,UNI TRAK
Posted 27 May 2011 - 05:20 AM
Posted 27 May 2011 - 06:03 AM
The part is shaped the same, just longer. As fas as PR2 etc. I have never used. I have a local suspension guy that I trust and he's never mentioned anything. I guess with all the R&D they do it would make a difference but how much, who knows. A lot would have to do with the level of the rider. I'd say of he's pushing it to the max every little bit helps. We've had the suspension re-valved and set up for his weight and couldn't be happier. Plus with a local guy he's always there for us.
Posted 27 May 2011 - 07:07 AM
Posted 27 May 2011 - 01:33 PM
Posted 27 May 2011 - 05:43 PM
You'd have to check part numbers but I'm almost certain it will. I believe we used '04 parts on our '07.
Posted 28 May 2011 - 03:25 AM
Thanks again xtred. We are well on our way to completeing our big wheel. I hope he slows down with his growing.
