YZ 250 Kickstarter 1998
6 replies to this topic
  • 125Wolf
Posted May 26, 2011 - 11:25 AM
Hi everybody Im new to this forum. I just purchase a 1998 Yz 250 and notice on my friends yz250 2001 model that his kickstarter uses a ratchet that locks in and makes it easier to start. Was it only fitted to the 1999 and onwards? or is there something wrong with my kickstarter. Also when I put my bike into gear it start crawling forward. Iv ajusted all the clutch cable settings and its still the same doesnt matter if the bike is cold or warmed up. Great forum you guy have :smirk:
  • dirtrider 11
Posted May 26, 2011 - 11:41 AM
don't know about the kick starter but for the clutch it could be notching in the basket and it could be the lever, what I did to mine was bend the lever forward a little that way you can pull it in farther so the clutch will fully disengage. if it is notching you will have to file the basket here is an article on how to do that.http://www.thumperta...ad.php?t=922634 hope this helps and welcome to thumper talk:thumbsup:
  • 125Wolf
Posted May 26, 2011 - 11:44 AM
Thanks man will check it out. Only starts crawling when it idles but if I rev the motor up abit then its fine
  • dirtrider 11
Posted May 26, 2011 - 11:52 AM
be careful not to break the lever if you decide to bend it they break pretty easy
  • mstyer
Posted May 26, 2011 - 12:16 PM
Sounds like the detent ball and spring may be missing from your kickstart lever. It should snap into place in the extended and closed positions.
Parts 13 & 14 on this schematic:
http://www.bikebandi...m8874#sch111319
  • CaptDan
Posted May 26, 2011 - 01:58 PM
...when I put my bike into gear it start crawling forward. Iv ajusted all the clutch cable settings and its still the same doesnt matter if the bike is cold or warmed up.
Most every Yamaha I've ridden would creep when in gear. That drag also makes it tricky to get the trans into neutral (when the motor is running), and almost impossible to kickstart the motor to life when in gear!
As far as I know, that's just the way they are. :smirk:
  • CaptDan
Posted May 26, 2011 - 02:26 PM
I agree with mstyer that it sounds like your kickstart lever just needs to be disassembled and cleaned/repaired.
If you need a complete replacement, Yamaha used the same kick lever on the YZ250 from 1988 to 1998.
:smirk:
Yamaha YZ85 2017 by Chris.GVS
Yamaha YZ85 2017
  • 0 reviews
Yamaha YZ85 2016 by Chris.GVS
Yamaha YZ85 2016
  • 0 reviews
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
Wiseco crank? Are they good by twostroke-notbroke
  • Hot  47 replies
