05 WR450 sunline fuel screw question
4 replies to this topic
  • Salinas_THumper
Posted May 25, 2011 - 09:31 PM
Posted ImageI was cleaning out my floatbowl last night and had the carb in my hand and a screw and washer fell down out of the carb. , there was no small o-ring but a large o-ring around the screw itself up on the shaft( sunline screw) I believe they came out of the fuel screw hole.
my question would be should i put the washer in the hole in the carb then the spring and then put the screw in the hole?
here is a pic of the washer and screw
Edited by Salinas_THumper, May 25, 2011 - 09:33 PM.
typo
  • MANIAC998
Posted May 26, 2011 - 04:25 AM
Yes, that's the order they go in. Your o-ring is probably still stuck in the hole, then the metal washer, then the spring, then the screw. Maniac
  • dgcars
Posted May 26, 2011 - 05:29 AM
Just make sure the 'O' ring is in there...
  • William1
Posted May 26, 2011 - 05:31 AM
to add,,, the oring on the screw shaft is to provide some friction to prevent the screw from vibrating out.
  • Salinas_THumper
Posted May 26, 2011 - 09:40 PM
thanks for the help guys
