'00 426 notched clutch basket - options?
6 replies to this topic
  • banda
Posted May 24, 2011 - 05:17 AM
Don't get mad at me for asking about '00 426 clutches - there's a lot of stuff in threads here already, and that's my problem - there's a little too much for me to digest.
So I know that there are some part swaps with '01 plates and rods that are popular. I know that aftermarket baskets for the '00 are non-existent.
My basket has notched fingers. I would like a lighter pull and smoother engagement.
I bought my bike used, and I don't know if the clutch parts are original.
How do I tell what I've got? Or does it matter? Should I get a '01-'02 basket and rod? Do I also need a new boss?
What are my options?
Thanks in advance for your help
  • silentv311
Posted May 25, 2011 - 04:56 PM
Just my opinion, I would stick to Factory OEM parts if you are not sure about parts exchange from later models or, purchase a Hinsen Clutch Basket designed for your year model and make. :smirk:)
  • 383firebird
Posted May 26, 2011 - 04:20 AM
I would file down and polish the fingers on your basket. I have done it and know others that have too with good results. Unless you wanna spend the money for new parts.
  • banda
Posted May 26, 2011 - 04:40 PM
Well, heck, that makes sense.
Ok, so a follow-on question. If it's time for new clutch plates, how do I go about identifying whether I have a '00 clutch or a '01 clutch? Does it even matter for clutch plate replacement?
  • 383firebird
Posted May 27, 2011 - 03:41 AM
if you look in the oem parts section and compare steels ,fibers and basket part #s they are they same for 00-02. i have always heard the 426 has a solid clutch and i have never had issues with oem parts.
  • nsanerod
Posted May 30, 2011 - 06:50 PM
https://picasaweb.go...feat=directlink - You can see the grooves in the clutch basket. They look like little squares where the friction plates rub. You can also see the file I used.
https://picasaweb.go...feat=directlink - Here is the "after" picture showing it smooth.
I had the same problem. I bought a used RMZ 450 and the clutch was grabby. I did some research and found the following advice:
-File off the basket to eliminate grooves.
I am no mechanic and I was able to do just this. Now, it is like butter! Pics show what I did. Keep in mind you have to remove the clutch basket. Be sure to clean everything before reinstall to get rid of metal shavings.
  • banda
Posted June 03, 2011 - 09:05 AM
Guys, thank you for pointing me in this direction. I will get in there with a file and let you know how it goes.
But - and I'm ashamed to say this - I replaced the clutch cable and lever, and thoroughly cleaned the clutch perch. The difference is like night and day. The lever action is buttery smooth, and the adjuster is a thousand times easier to operate. I think it could all be even better, so I'll get in there with the file and replace the plates, and I'll see what I get.
Thanks again.
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
  • Hot  47 replies
  • 5 replies
  • 10 replies
