head leaking on 10
4 replies to this topic
  • moto278
Posted May 22, 2011 - 11:27 AM
Ok i just reassembled my top end on my 10 450 with new gaskets and piston and rings from cp. I just had it out and noticed air coming from the little hole next to the coller line on the kickstart side of the motor. After a quick ride noticed it also spits out a small amount of oil as well. Any thoughts?
  • Chazmagnum
Posted May 22, 2011 - 11:52 AM
Check your valve cover gasket. It's tough to get in the right spot.
  • todds924
Posted May 23, 2011 - 10:27 PM
Only way oil can come out that hole is through the valve cover gasket leaking around the spark plug hole
Pull your plug cap/coil and I bet its all oily
  • moto278
Posted May 27, 2011 - 05:21 PM
So on putting ny motor back togethr i dropped a smallbolt in the timing. Chain. My flywheel puller doesn't fit. Where can I find one that works?
Posted May 27, 2011 - 07:19 PM
The flywheel puller for an '06 or later YZ450 will fit, as will one for an '02-'08 CRF450.
  • 5 replies
  • Hot  30 replies
  • Hot  47 replies
