Building YZ-f bike
15 replies to this topic
  • sledtrash
Posted May 20, 2011 - 09:52 AM
Hello I'm putting together a bike from an aluminum frame I purchased recently and I want some advice. To keep the build as cheap as possible I'm buying used parts. I need to know what years of parts would be the best to throw on this and which years will work I guess. The frame is a 07 YZ. I'm building this for more enduro style riding.
suspension & brakes:
Rear: I've already bought a 06 swing arm should I go with a (new) lowering link and what year of shock has the best valving? Brakes: don't have any of that yet what caliper's and master cylinder's should I go with (year) are there better years of rotors?
Front I don't have anything from triple clamps forward so any advice on anything on the front, forks, triple clamps brake set up
NOTE: This is not a 4t :smirk:, but the other parts regard the 4t frame.
I'm running a 500cc 2t air-cooled engine so would I have problems running a yz-f carb on the engine, would the accelerator pump give me problems?
  • cowboyona426
Posted May 20, 2011 - 10:50 AM
07-09 have wave style rotors OEM, 06 models have standard rotors
The 08-09 are supposed to have the best suspension... 06 suspension sucks but you'll be revalving it anyway so maybe a moot point
I don't recall any changes to master cylinder/calipers but gray will probably correct me
Posted May 20, 2011 - 12:13 PM
Don't waste too much time on the carb. It will be pretty much 100% wrong for the engine. It may or may not even be tunable, depending on the availability of correct needles and slides for the 2-stroke.
YZ rear brakes are all about the same from '03 on, other than the wave feature. At the front, it will depend on the forks. '06-'07 YZ450 used the same MC/caliper combo as the bikes back to '03 and earlier did, but the '08+ YZ450 and the '07+ YZ250F used a smaller one that has to be used as a set with the forks.
  • sledtrash
Posted May 20, 2011 - 12:28 PM
Are their better or worse for the front suspension?
Do the wave style stay cooler easier?
Posted May 20, 2011 - 12:32 PM
Is what better than what?
Wave rotors clear mud from the brakes better than round ones. That's it.
  • sledtrash
Posted May 20, 2011 - 03:21 PM
Which are set up the best from the factory if there is a difference.
I also have to buy triple clamps for the bike as well.
or in your opinion, would I be alright with anything that would work on my bike?
Posted May 20, 2011 - 04:35 PM
Tires, fenders, handlebars? What?
  • sledtrash
Posted May 20, 2011 - 05:33 PM
Forks and Rear shock's, did they change valving year per year?? or is it the same basic stuff. I'm wondering what year would be the best to look for?
  • beezer
Posted May 20, 2011 - 07:10 PM
Blue fenders have been proven to make more horse pressure on the dyno.
Posted May 20, 2011 - 08:14 PM
Anything '06 and up is good. The later, the more refined, of course. The '06 fork requires an '06 clamp set, but '07 -'09 will interchange. The steering stem in the '08-'09 is shorter by 5mm, though, so you need to use either the full '06 set up, or an '07 clamp set with '07-'09 forks and matching front brake stuff.
  • sledtrash
Posted May 20, 2011 - 08:54 PM
Perfect just what I needed to know so the newer the better. How about rear shock and linkage any major changes?
Like I stated I think I'm going to lower the bike for woods use so I'm thinking that any decent priced shock 06+ would be fine.
Any I think that black although a few horse's less will give me more aerodynamics and therefore beat out the horse power of the blue one. :smirk:
Posted May 21, 2011 - 12:01 AM
Swing arm and link from '06-'08 should interchange. The '09 will work if you use the '09 linkage, but then you'll also need the '09 rear wheel and axle.
  • dgcars
Posted May 21, 2011 - 12:12 AM
:smirk:
  • sledtrash
Posted May 21, 2011 - 10:10 AM
Thanks Gray.
  • SEOINAGE
Posted May 21, 2011 - 08:40 PM
Very cool, although I can't give advice, others have done so, the motor an '84 or different year? I would love to see something like this when finished.
  • sledtrash
Posted May 22, 2011 - 11:18 AM
very cool, although i can't give advice, others have done so, the motor an '84 or different year? I would love to see something like this when finished.
82 465
  • 0 replies
  • Hot  113 replies
  • 10 replies
  • On January 15, 2017
