11 years, 325ccs, 5 valves later...
44 replies to this topic
  • johnny6speed
Posted May 18, 2011 - 05:29 PM
TLDR:
09 450 leftover
Came from 125 2t 11 years ago
Power is fun
Makes cool sounds/occasional pop on decel
Cold starting sucked (bumped it)
Out of shape fat John is out of shape and fat
FC fat guy (255lbs) .53/6.0 springs/FF5 on the way next week
Changed oil/yamalube 10-40 dino/oem filter
Need to make some adjustments
Size 14 boots do not work with out of crate shift/brake lever settings
Must move bars forward/man boobs in way/6' feet tall with boots
Raise idle/order FWW/low rpm flameouts stink
Going to putt around on weekend practice day at local track
Having a beer trolling TT browsing owner/service manual
:smirk:
  • Ryan426
Posted May 18, 2011 - 06:17 PM
sweet!~
  • Yamaryder29
Posted May 18, 2011 - 07:12 PM
Looks good. Wish I had one.:smirk:
  • RiderX
Posted May 18, 2011 - 07:22 PM
For cold starting try twisting the throttle 3 times and pull the cold start choke, then kick.
  • dvn
Posted May 19, 2011 - 12:55 AM
+1 Mine was a bitch when new as well. It will start great once you get the procedure down and get a couple hours on it. Great bike! :smirk:
  • yz450fcranker
Posted May 19, 2011 - 04:55 AM
get her fired up and ride all day till it gets tired
  • BlueMagiC
Posted May 19, 2011 - 04:57 AM
I remember when i 1st started riding big Yamaha 4 strokes and how hard they were to start...until i learned 1 thing...NEVER touch the gas when starting them. At least none of the 426's or 450's ive ridden.
  • Yamaryder29
Posted May 19, 2011 - 05:07 AM
That's what I was also told about 8 years ago when I had my first 250f and have obeyed by that rule. Never had issues starting this way. Everyone has there own technique, you just have to learn what works for you.
  • Polar_Bus
Posted May 19, 2011 - 06:36 AM
My '07 450 likes a pump or two on the gas no matter what when cold. I'ts when the engines are hot that you DON'T want any raw fuel ingested into the engine, otherwise you will be kicking for 15 min straight with the hot start pulled to get them lit off again ! :smirk:
  • cowboyona426
Posted May 19, 2011 - 06:41 AM
:smirk:
My 06 450 likes a few twists of the throttle on cold starts as well. You'll just have to figure out what works best for your bike.
  • capt justin
Posted May 19, 2011 - 06:53 AM
my buds 2006 yz450 likes 3 whacks on the throttle then kick giving it NO gas, maybe lift the choke when cold but thats it. starts less then 3 kicks most times
  • sledtrash
Posted May 19, 2011 - 06:55 AM
depends on if it's cold or not. If it's hot outside yes. but in the cold 3-4 pump's will give the engine enough gas to fire up. Instead of having to tip it on it's side like some of the older big bore bikes. :smirk:
Edited by sledtrash, May 19, 2011 - 07:13 AM.
  • BlueMagiC
Posted May 19, 2011 - 07:04 AM
While we are on the subject of the various ways of starting these beasts, i need to say that the only time my 03 450 absolutely refuses to start is when it is hot and the bike is dropped or laid over on its side. At this point i basically just let it sit for 10-15 mins because it simply WILL NOT start no matter what i do...is this a common problem?
  • RiderX
Posted May 19, 2011 - 07:19 AM
This is true for any four stroke bike that's at normal operating temp, but a cold motor (by cold I mean not run yet) 2-3 twists of the throttle BEFORE you kick will save you some kicking, guaranteed. Try it.
  • BlueMagiC
Posted May 19, 2011 - 07:21 AM
Mine starts 1st or 2nd kick every time when its cold with no twists, maybe im just lucky.
  • RiderX
Posted May 19, 2011 - 07:22 AM
In this situation I pull the hotstart and hold the throttle wide open and kick about 10 times to clear it out. Then I close the throttle and kick. Usually works.
  • BlueMagiC
Posted May 19, 2011 - 07:26 AM
Wouldnt holding the throttle wide open flood it even more?
Posted May 19, 2011 - 07:27 AM
Next time you encounter that situation, try this: Open the throttle all the way and hold it there. Slowly turn the engine through about 4-5 compression strokes. Not fast, not hard, just move air through the engine. Take maybe 30-45 seconds to complete the process. Then close the throttle and try a start using the hot start with the throttle closed OR with the throttle cracked open about 1/6. Always worked for mine.
  • BlueMagiC
Posted May 19, 2011 - 07:32 AM
Ill give that a try the next time i dont see that small stump going uphill (Thats what happened last time). Thanks grey.
Edited by BlueMagiC, May 19, 2011 - 10:36 AM.
  • RiderX
Posted May 19, 2011 - 07:38 AM
It only gives one squirt on the initial opening of the throttle, which clears out when kicking while keeping it held open.
  • 0 replies
  • Hot  36 replies
  • Hot  30 replies
  • Hot  28 replies
