stator ? "electrex"
6 replies to this topic
  • uw153
Posted August 22, 2003 - 11:24 AM
Has anyone bought a stator from Eletrex? Mine has a bad coil in it and Honda is VERY proud of their's. I figure Electrex's $151.00 is better than Honda's $380.00. But I want to know if it will last. Thanks all.
  • Sherick
Posted August 22, 2003 - 12:57 PM
I've used Ricky Stator in the past, the stuff has always worked well.
http://www.rickystat...R650stator.html
  • uw153
Posted August 23, 2003 - 06:07 AM
Yeah, I already contacted Ricky's stator, they said they didn't make anything for the XR650L. That's normally my luck. At least it's not as bad as my DR650, no one make squat for that thing. :)
  • Moredesert
Posted August 24, 2003 - 07:10 PM
Why don't you just rewind it your self. I rewound my stator on the XR650R and was easy. In your case find out what size wire you need and just copy what you already have. Unwind yours making notes on which way each coil is and how many turns on each post. Put on some epoxy and your done!
  • Burnrider
Posted August 27, 2003 - 12:15 PM
I did a KLX 300 rewind using Honda XR sources. The Honda riders had the most info on it.
http://www.all-offro...atorRewind.html
  • uw153
Posted August 28, 2003 - 05:49 AM
Hey thanks guys, I supposed it can't hurt to rewind it. Worst case, I have to buy the Electrex one. Where did you source the correct wire and epoxy??
  • Burnrider
Posted August 28, 2003 - 06:08 AM
www.mouser.com for the wire
www.encotools.com for the epoxy (listed as gray epoxy price $18.95)
505-2793 2 OZ FLEX. GRAY 3M TWO PART EPOXY
  • Hot  29 replies
  • Hot  60 replies
  • 9 replies
  • Hot  35 replies
