A few Q's for Grey and the other Yzf gods
11 replies to this topic
  • Dick Falcon
Posted May 17, 2011 - 06:57 AM
Ok guys ,Ive got a 09 yz 450f.i have 21 hare scrambles on the bike.latlely its running hot ,and it getting harder to start.im thinging it top end and cam chain time.What do you guys think??
k
  • yz450fcranker
Posted May 17, 2011 - 07:11 AM
Get an Iridium spark plug cr8eix fill with new coolant unless you Want a piston go get one OEM pistons will fit right for another 21 hare scrambles if you are doing it again
  • yz450fcranker
Posted May 17, 2011 - 07:12 AM
Also have that head off the bike and check all parts for wear and go do it yourself
  • Dick Falcon
Posted May 17, 2011 - 07:56 AM
i just put a new plug and engine ice,its just not running right.how can i tell if the cam chain is stretched??
  • rdefonce
Posted May 17, 2011 - 08:22 AM
Just be on the safe side and replace it.
harder starting could mean the valve clearances are out of spec. check the valve clearances and re-adjust if necessary (since you will have the valves off anyway if you swap out cam chain.)
Posted May 17, 2011 - 09:12 AM
One good visual indication of the wear on a cam chain is how far it will curve laterally.
They are so cheap, though , that you should just install one as a routine item every season or so.
A leak down test will tell you a great deal about the condition of the top end and what it really needs.
  • kawi380
Posted May 17, 2011 - 09:14 AM
I've found that hard starting seems to point to a valve issue. Cam chain problems could be tied in to that.
  • carver
Posted May 17, 2011 - 09:19 AM
Harder to start and hot running also opens the possibility of dirty jets/passages.
It will usually also show that through a decel. popping, but cleaning the carb/jets also a consideration.
  • yz450fcranker
Posted May 17, 2011 - 12:00 PM
tell me what you find when you are done because i have an 09 too and it starts first kick only when warm
  • Dick Falcon
Posted May 17, 2011 - 12:39 PM
thanks guys,going takigi apart now.
  • brentn
Posted May 17, 2011 - 03:58 PM
What do you recommend for a replacement? OEM?
I'm guessing this isn't like changing a drive chain where both sprockets should be changed at the same time?
thx
Posted May 17, 2011 - 04:36 PM
The manual says to change all the sprocket with it, but that means both cams and the crank. So, no, only the chain unless one of them is really terrible.
  • Hot  94 replies
  • Hot  47 replies
  • 0 reviews
