lean, rich or both
2 replies to this topic
  • thumpawoody
Posted August 22, 2003 - 03:17 AM
my 03 450 requires the hot start to start at any thing past cold (choke on).-indicating a rich mix
when running pulling the hot start raises the rpm considerably.- also indicating a rich mix
when backing of with over run popping is common.-indicating a lean mix
if I'm not mistaken these situaions would all run of the the idle circuit of the carb so why do the results contradict each other
  • tctrailrider
Posted August 22, 2003 - 08:48 AM
Thumpa,
On decel a lean pilot will cause a loud bang or two. Popping on acceleration but bang on decel.
  • Indy_WR450
Posted August 22, 2003 - 02:06 PM
You can get banging and sputtering sounds from being to rich at decel off the throttle. It sounds distinctly different from a lean popping at decel but some people can get the two mixed up. Once you have jetted to both lean and rich in the same day you will know the difference. I think you are running rich by the sounds of it. :)
