Axel nut size
16 replies to this topic
  • blakers213
Posted May 16, 2011 - 09:08 PM
What is the true size of the rear axel nut on a 2009 YZ450F. Owners manual says nothing. I have been using a 32mm socket and it always feels a little loose and now the nut is starting to round off.
  • d4yton
Posted May 16, 2011 - 09:09 PM
im almost 100% sure that 32mm sounds right, maybe its your sockets?
  • sacfelix
Posted May 16, 2011 - 09:23 PM
1 1/16"
  • blakers213
Posted May 16, 2011 - 09:34 PM
1 1/16"
Funny you should say that. I know it has to be metric but needed a wrench at a track one day and a guy gave me a sae wrench and I tried it and it worked great but I didn't remember what size it was.
  • sacfelix
Posted May 16, 2011 - 09:43 PM
I bought a Pittsburgh ratchet wrench this size and it works great.
  • carver
Posted May 16, 2011 - 10:05 PM
I can't tell you if it's a 32 or a 31 but it's definitely not a 1 1/16 (27mm)
That's for a pre-'09 22mm axle. You have the larger 25mm axle that started in '09.
  • yz450fcranker
Posted May 17, 2011 - 06:59 AM
mine started to round off too im using a 32mm too but i wont change it if im not touching it for another 10 rides
Posted May 17, 2011 - 08:13 AM
32 is 1 1/4" (1.2598"). Try a 1 3/16" (30.1625 mm)
  • carver
Posted May 17, 2011 - 09:05 AM
A 1 3/16" won't work. The nut measures larger than 1 7/32.
I just went out in the garage and tested each. Here are the results from loosest to tightest.
32 12 pt.
32 6 pt.
1 1/4 12 pt.
1 1/4 6pt.
My rec. is to use a 1 1/4 6pt., it was fairly good.
The possibility of a 31mm is still there, however,
that's approx. 1 7/32 and the nut measures larger than that
along with the fact that the 1 1/4 6pt. didn't leave enough room for 1/32 imho.
Another thing, and I don't mean to insult anyone, but I watch guys put large sockets and torque
on a nut by just applying force to one end of the wrench. That cocks the socket and will round off
the nut even if the socket is correct. Applying equal and opposite force at the head keeps the socket flush.
I know most know that but it just had to be said here.
  • blakers213
Posted May 17, 2011 - 09:40 AM
Just took the nut to Sears and a 11/4 inch socket fit great. Don't understand why but it worked better than any 32mm I tried.
  • stroker101
Posted May 19, 2011 - 08:15 AM
1-1/4" here also (2009 YZ450F)
  • JDrider
Posted November 25, 2013 - 09:19 PM
I know this topic is old but it made me go out and buy the wrong socket. I have a 2010 YZ450F and the rear axle socket is 30mm. I tried three before I got it right :-). So 2010 through at least 2013 are 30mm.
  • k.g
Posted December 02, 2013 - 09:58 AM
An All/16" wrench is a perfect fit if you can't find the right tool :smirk:
  • Bturner
Posted December 07, 2013 - 06:59 PM
1-1/4 fits perfect for my 09. It's the only size I've used on all my 450/250s that I can remember. I bought the socket just so I could adjust my chains.
  • JDrider
Posted December 08, 2013 - 03:59 PM
That is pretty unusual. My last three bikes have all been different . 07 CRF230F 24mm; 08 YZ250F 27mm; 2010 YZ450F 30mm; Iv'e never seen one as big as 1-1/4 before. I'm not doubting you, just saying that is very uncommon.
  • Bturner
Posted December 08, 2013 - 04:08 PM
Yea, I dunno man. Like I said, I've always used that socket for my bikes. Same as the guy a few comments above, 1-1/4 for the 09. Fits great!
Posted December 09, 2013 - 07:53 AM
Not
  • On January 15, 2017
  • 0 replies
  • 10 replies
  • Hot  47 replies
