400 -vs- 426
3 replies to this topic
  • motoxpress
Posted May 14, 2001 - 08:59 AM
What's the differences between the '99 400 and the 2K 426? How much more power does the 426 have and is it needed? What else?
Thanks
  • Ga426owner
Posted May 14, 2001 - 09:01 PM
A lot, buy the 426..................you will be much happier.
  • Hick
Posted May 14, 2001 - 05:15 PM
For 2000 Yamaha “redesigned” the clutch, adding a plate, shortened the frame behind the steering head 5 mm, moved the bar mounts forward 5mm, raised first and second gear ratios, & changed to alum. subframe. The carb is also redesigned and I think the header is different. I may have forgotten a few things there…
…but they should’ve left the clutch alone.
The motor changes included a new piston, barrel, crank, & rod (the small end is bigger) but the stroke remained the same.
I also think the ’00 has stiffer fork springs and the valving is probably a little different. You don’t “need” a 426. They feel tons faster, especially down low, but, depending on the conditions, are probably not much better.
I have an ’00 but have ridden a few ‘99s. Hope this helps.
  • teamtoxic
Posted May 14, 2001 - 05:24 PM
<h3><font color="navy">There's NO replacement...
for DISPLACEMENT! :)</h3>
<h4>Go with the 426</h4>
~~~~~YaMaHaFoUrTwOsIx~~~~~
  • Hot  38 replies
  • Hot  28 replies
  • Hot  30 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
