rev limiter too early
4 replies to this topic
  • gasgasser
Posted May 14, 2011 - 10:30 PM
Picked up an 01 CR250 the other day that needs a clean up.
When it hits powerband the revs bounce like its hit a limiter too early. So far I checked the copression 165bls and cleaned the carb and jets out. Fired it up and its still doing it.
It's probably going to be a process of elimination but was wondering if it was something someone had seen before. Or just put what you'd look at next.
I have a fully working 99 cr250 I've just fixed up to borrow parts off too.
  • tidtid
Posted May 14, 2011 - 11:04 PM
i don't think it has a rev limiter. sounds like the main jet is too big and it needs leaning out a few sizes. Try warming up the bike then make a long wide open run if it does not clean out try it again but drag the back brake some, if it is just alittle rich the extra load from dragging the brake will make enought heat to clean it out or just dop the main jet size and try it again. maybe a new plug also.
  • 01cr80
Posted May 14, 2011 - 11:11 PM
are you warming it up?
  • gasgasser
Posted May 15, 2011 - 12:30 AM
haha yeah, had a few bikes in my time so know about warming up 2strokes
  • choppertown
Posted May 15, 2011 - 07:42 AM
2 strokes dont have a rev limiter...your probebly running out of gas in your bowl and its cutting out...
Honda Cr85 problem by Bashkillem69
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  30 replies
I got a head scratcher for you guys by dcr98
  • Hot  36 replies
CR125 High Revving on Start Up by Will I Am
  • Hot  28 replies
optimum lowend torque sprocket size cr80r by ericinkmonster
  • 17 replies
New to the forum. Question regarding cylinder scoring and break in by BlakeCR
  • Hot  50 replies
