yz 426 to wr trans. swap
6 replies to this topic
  • houndog426
Posted May 12, 2011 - 08:41 PM
ok. my local dealer could not give me a straight awnser, so here it is..... can you put a wr trans. in a yz case? some said maybe, some said i dont know, can it be done. o ya the bike is street legal so thats why im asking.
  • Birdy426
Posted May 12, 2011 - 10:19 PM
It certainly can be done. Search the YZ forum and you willo find all kinds of help...
Posted May 13, 2011 - 06:47 AM
Yes. The WR426 parts will bolt directly into a YZ426. To change the gear set, you will need the 9 WR gears and the WR main shaft (the first gear pinion is cut directly on the shaft). The output shaft and all other trans components are the same.
  • houndog426
Posted May 14, 2011 - 01:31 PM
someone said i would need the heavy flywheel also... but i thought that was just to keep it from stalling on the street.
right now im runnig 16/46 sproket setup will the wr trans. give me more on the street?
  • ktmracer53
Posted May 14, 2011 - 04:29 PM
a 426 running a 16/46? is that not enough for road or what?
Posted May 14, 2011 - 05:30 PM
No, the stator is bigger, so the flywheel has to be bigger too, or they won't fit together.
  • houndog426
Posted May 15, 2011 - 05:11 PM
its not that its not enough, it just lugs in every gear when in town, and ive heard the WR, trans. has more streetable ratios.... but yes its plenty for the road as long as it has no stop lights.... but always open to sugestion and others experience, im a mechanic and im always looking for something to work on.
  • Hot  47 replies
  • Hot  30 replies
  • Hot  36 replies
