Help, trouble mounting shock WR400
1 reply to this topic
  • fruntrangr
Posted May 11, 2011 - 10:56 AM
Seriously, I've finished replacing all the bearings in the rear end. Now it's time to re-install the shock and I can't get the top bearings to mate up with the frame, it just won't fit. I seems I'm to use the smaller brass colored collars in the bottom end of the shock right?? Any ideas? Anyone else run into this? The shock dropped right out when removed so no damage there. I'm about ready to remove fender and airbox but thought you guys might have some ideas.
Thanks in advance.
  • MANIAC998
Posted May 11, 2011 - 07:22 PM
If I'm hearing you correctly, you just need to twist the shock body alittle to get them to line up. It sounds like your upper shock mount isn't perfectly lined up with the lower shock mount. Is this what you mean? Maniac
