2000 WR400F Rebuild - Process Pictures.
214 replies to this topic
  • LIVETOSHRED
Posted May 11, 2011 - 07:58 AM
Hey all,
Been a long time lurker and first or second time poster.
The bike was a best friends who passed back in 2008. The bike was given to me by his father. as all me and his son did was ride. It has sat for a couple years and finally, I pulled it out, dusted it off and started this Memorial build for Robert "Big Sexy" Kennedy.
The motor was just rebuilt by Jeff at Temecula Cycles with a new piston, rings, adjusted valves, new water pump seal and a quick run through the carb. It would fire up but only with the choke on so I know the carb is going to need some loving once the build is done.
Here are some pic's of the process thus far. I have spent about 4 days on it to get it torn down. There are some big plans for this bike and I'm hoping that by the time it's completed, it will be one of a kind.
Before Photos:
Day 1:
Day 2:
Day 3:
Day 4:
  • Markjb85
Posted May 12, 2011 - 02:28 AM
Looks good so far, its alot of work to pull them down isnt it.
Check out my rebuild http://www.thumperta...ad.php?t=971921
  • chiefster1976
Posted May 12, 2011 - 03:07 AM
Hey, whats your plans for this rebuild? Full respray,every bearing replaced, No expense spared??:thumbsup:
  • LIVETOSHRED
Posted May 12, 2011 - 11:51 AM
Day 5 - That part sucked.
  • LIVETOSHRED
Posted May 12, 2011 - 11:54 AM
The latter method for the most part. Everything is getting powdercoated in one way or another and by the time this is done, i'm hoping to obtain some help on how to plate it in the lovely state of California so I can putt it around on the streets.
My main purpose of this build is to bring it back to life for my fallen friend...
  • mrlopez
Posted May 12, 2011 - 09:57 PM
what part of cali you live?
  • LIVETOSHRED
Posted May 13, 2011 - 07:06 AM
Southern California. Live in Corona.
  • LIVETOSHRED
Posted May 13, 2011 - 07:08 AM
Day 6 - Off to powdercoat thanks to Inland Powder Coating.
  • 123BigcoopDawg576
Posted May 13, 2011 - 07:20 AM
Killer jobs so far! Looking forward to seeing more! I sent you a PM btw... :thumbsup:
  • mrlopez
Posted May 13, 2011 - 07:22 AM
Well I plated it mine 3 years ago here in Fresno Ca and I just recently plate it a 02 CRF450 ;-)
Man that thing is going to look awesome
  • Kawidad
Posted May 14, 2011 - 12:33 PM
Junk the stock carb and get a take off from an 03-06 WR/YZ450. It runs much better and no worries (supposedly) about sucking in the slide vacuum plate and trashing the engine.
  • LIVETOSHRED
Posted May 15, 2011 - 07:14 AM
Have you done this? I have done a bunch of reading and research about jetting and the setup on this bike so when it gets to that point, I have a good starting point. I have read good things about the JD Jetting kit but am open to options.
I am kinda a fickler about my 4 strokes running their best. My YZ450F took a few weeks to get dialed but now it runs amazing. No popping on deceleration, no lag on the get-go and idle's like a champ. I am optimistic about getting the same results with the WR.
  • Kawidad
Posted May 15, 2011 - 09:09 AM
Yes.
Mine sucked the vacuum plate, but luckily no damage that I could find. I replaced it with the 450 carb and it runs much cleaner. Jetting is very similar, so I suspect the claims that the gen3 FCR carbs are more forgiving are true.
  • chiefster1976
Posted May 16, 2011 - 04:29 PM
Hi Livetoshred...
The Wr450F is thursty on fuel and i have had a flat spot with no luck 2 bikes shops to solve the problem..
Try these specs of a Wr450F carby expert tuner..
http://www.dirtbikew...ead.php?t=77742
I am following these specs to the letter to hopefully solve the problem..
Just to bare in mind using the 450f carby!!! :smirk:
adjustable Acc power pump,
adjustable fuel/mix screw..
As above jetting specs...
  • LIVETOSHRED
Posted May 16, 2011 - 05:34 PM
Hi Livetoshred...
If I decide to go this route and trash the WR400F carb, where would be a reasonable place to score a WR450F carb?
  • byggd
Posted May 17, 2011 - 01:20 PM
Me too :smirk:
  • LIVETOSHRED
Posted May 18, 2011 - 05:26 PM
Day 7 - Parts are due back from Powdercoat anytime so time to start on the small stuff!
Before
After
  • Kawidad
Posted May 19, 2011 - 12:00 PM
Only reasonable places are Krogblog (aka Craig's List) or Fleabay.
  • Just_a_trail_rider
Posted May 19, 2011 - 09:35 PM
Before
After
What did you use.... steel wool? Look good.
  • LIVETOSHRED
Posted May 20, 2011 - 07:47 AM
200 Grit sand paper to 100 Grit to Steel wool. I will polish it when I get the other side done. it's a pain! haha
