RM 2 stroke set up data base
Hey guys. I stole this straight from the YZ forum. Thought it would be usefull info to have here for the RM's as well for reference.
RM Year:
RM engine size:
Carb mods(PowerNow, Wings, JDJetting, ect..):
Air Filter (stock?)
Main jet:
Pilot Jet:
Needle model/Clip position:
Air screw:
Altitude where you ride:
Temps:
Reeds:
Pipe/silencer:
Head mod:
Other mods(FWW, ect.):
Type of fuel:
Type of Premix/Ratio:
Type of Trans oil:
Type of riding(MX, trails/technical, desert ect):
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End):
Rear Tire:
Gearing (sprokets):
Degree of satisfaction:
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots:
Notes:
  • Like 2
Ok I'll go first
RM Year: 2003
RM engine size: 250
Carb mods(PowerNow, Wings, JDJetting, ect..): #7 slide
Air Filter (stock?) Uni filter
Main jet: 170
Pilot Jet: 45
Needle model/Clip position: N8RH 2nd
Air screw: 1-1.5 turns
Altitude where you ride: 500'-2000'
Temps:60-70F
Reeds: Vforce3
Pipe/silencer: stock expansion, PC 296 silencer also PC works and 304 silencer
Head mod: stock
Other mods(FWW, ect.): 10oz FWW, Hinson clutch basket
Type of fuel: 2 parts 91 pump to 1 part Avgas 100ll
Type of Premix/Ratio: Amsoil Interceptor 31-1
Type of Trans oil: Bel Ray gear oil
Type of riding(MX, trails/technical, desert ect): A level Woods racing and some MX, soft terrain, mud, sand, rocks, etc
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): Lugger in the tight, screamer in the open
Rear Tire: Bridgestone 404
Gearing (sprokets): 13/51
Degree of satisfaction: 9
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: little with 296 silencer, none with 304
Notes: This was a cheap project bike I rebuilt from the ground up to be my woods racer this year. Very happy with the outcome. First race is this weekend so the real test begins....
Edited by tribalbc
  • Like 2
RM Year: 2003
RM engine size: 250
Air Filter (stock?) Twin Air
Main jet: 168
Pilot Jet: 45
Needle model/Clip position: Forgot what it was.
Air screw: 1-1/2 to 1-3/4 turns
Altitude where you ride: 1300'
Temps:30-110F ? Welcome to Oklahoma
Reeds: Vforce old style
Pipe/silencer: PC Platinum and 304 silencer
Head mod: milled just enough to clean up the gasket area
Other mods(FWW, ect.): Full henson clutch system, Marshal suspension, RG3 clamps, Renthal twin walls,
Type of fuel: 91 pump
Type of Premix/Ratio: Klotz 32-1
Type of Trans oil: 10w-40 oil
Type of riding(MX, trails/technical, desert ect): MX, soft terrain
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): WFO
Rear Tire: Dunlop MX31
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: none, but it will leave the rear fender with a smoke tint.
Notes: I like this bike better than my 06 YZ450F.
RM Year: 2001
RM engine size: 250
Carb mods(PowerNow, Wings, JDJetting, ect..): no mods
Air Filter (stock?) No Toil
Main jet: 168
Pilot Jet: 45
Needle model/Clip position: #2 from the Bottom
Altitude where you ride: 6-700'
Temps:45-90F
Reeds: Stock
Pipe/silencer: Stock
Head mod: Stock
Other mods(FWW, ect.):Henson Basket, Tusk clutch, Race Tech front suspension
Type of Premix/Ratio: Klotz supertech 32-1
Type of Trans oil: Rotella 15-40 oil
Type of riding(MX, trails/technical, desert ect): from hell to high water
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End):Depends on the riding conditions and terrain
Both Tires: Michelin Starcross
Gearing (sprockets): Stock
Degree of satisfaction: 8
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: Little to some
Notes: First bike since 16yo on a 82 CR250R
RM Year: 2005
RM engine size: 250
Main jet: 168
Pilot Jet: 45
Needle model/Clip position: #3 from the top
Air screw: 1turn out
Altitude where you ride: 2995-6200'
temps- 30-105F
Reeds: V Force Delta 3
silencer: R304/Type 296 SA
Head mod: Stock
Other mods(FWW, ect.): Pro Circuit Exhaust/Pro Circuit Triple Clamps,bar mounts/Black Excel Rims/Works Connection Rad braces,skid plate/Aluminum bearing throttle tube/ASV levers/Renthal TwinWalls/Hinson Clutch Basket,Inner Hub/Renthal Chain,Sprockets/Racetech Suspension front/rear
Type of fuel: 50/50
Type of Premix/Ratio: Maxima 927!! (The Champagne of Premix!!) 32:1
Type of Trans oil: Bel Ray 10W-40 Gear Saver
Type of riding(MX, trails/technical, desert ect): All of it
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Wide Open
Both Tires: Maxxis IT
Gearing (Sprockets): 13-51
Degree of satisfaction: 10
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: Little to some: Little to none.
Notes: It's been by far the best and funnest bike I've ever had. I've owned it since 05' and don't plan on ever getting rid of it either.
  • 3 weeks later...
RM Year: 2006
RM engine size: 125
Carb mods: None
Air Filter (stock?) stock
Main jet: stock
Pilot Jet: stock
Needle mel/Clip position: stock
Air screw: stock
Altitude where you ride: 600-800
Temps:45-90F
Reeds: Vforce 3
Pipe/silencer: DEP full exhaust
Head mod: Stock
Type of Premix/Ratio: Motorex Crosspower 30:1
Type of Trans oil: Motorex Crosspower 5w40
Type of riding: Trails
Both Tires: Dunlop d756
Notes: Awesome bike
RM Year: 1991
RM engine size: 250
Carb mods(PowerNow, Wings, JDJetting, ect..): stock
Air Filter (stock?) Twin air
Main jet: stock (170?)
Pilot Jet:stock
Needle model/Clip position: stock (i guess middle)
Air screw: 1 3/4 turns
Altitude where you ride: about sea level
Temps: 10-20C°
Reeds: stock
Pipe/silencer: stock and spes (spes takes it quicker in revs, but revs out pretty quick too, thats why i prefere the stock one)
silencer is stock, but cut off 5cm for better high powerband power
Head mod: stock
Type of fuel: 95 or 98 pump
Type of Premix/Ratio: plutoline, 3%
Type of Trans oil: 10w40
Type of riding(MX, trails/technical, desert ect): mx races, heavy dirt, hard pack track
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): depends on the track
Rear Tire: pirelli scorpion
Gearing (sprokets): 14-49
Degree of satisfaction: i always get a boner
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots:little
Notes: i bought it with 14-49 gearing, goes fine if the piston is new
as the piston wears, it gets harder to keep it reving in 3rd when coming out of a corner (depends on the track), but i orderd 13-50 now, i'll see what that gives
RM Year: 2008
RM engine size:125
Air Filter: Stock and twin air.
Main jet: 380
Pilot Jet: 40
Needle model/Clip position:Stock/2
Air screw:2
Temps:10-20C
Reeds: Stock
Pipe/silencer: Pro circuit/R304 short
Type of fuel:99 octane pump.
Type of Premix/Ratio:Putoline MX5, 40/1
Type of Trans oil:Putoline GP10
Type of riding(MX, trails/technical, desert ect):MX
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): WO
Rear Tire:
Gearing (sprokets):12/52
Degree of satisfaction: Ok.
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots:None.
I tried JDjetting but couldn`t figure it out. Bogged when I went from 1/4-full trottle.
Would be nice if this post stays current. Could build to be a very informative thread for the main sticky post. Keep it alive.
I was thinking the same thing the other day and was going to revive this thread, but you beat me to it ?
Do we have any moderators in the RM forum to move this to a sticky???
  • 2 weeks later...
RM Year: 2001
RM engine size: 125
Carb mods(PowerNow, Wings, JDJetting, ect..): Stock
Air Filter (stock?) TwinAir w/NoToil Oil&Grease
Main jet: 380
Pilot Jet: 40
Needle model/Clip position: Stock - 2
Air screw: 1.5
Altitude where you ride: 100-800ft
Temps: 45-90F
Reeds: Boyesen Rad Valve
Pipe/silencer: Pro Circuit Works with R304 Shorty Silencer
Head mod: Eric Gorr High Compression Race Gas Mod
Other mods(FWW, ect.): Eric Gorr Pro Supercross Porting Option, Crankcase matching, OEM Piston/Rings/Crank Assy, Complete Hinson Race Kit Clutch Assy, Polished Cluch Pushrod, Boyesen Sand Cast Engine Covers, HyGear Suspension, Pro Circuit Axle Blocks, Gold Excel Rims, Galfer OS front brake kit and wave rear, Braided Lines, Universal Triple Clamp, ProTaper RM Lo Bars, ProTaper Throttle Tube and Pillow Top Grips, Pro Circuit front brake lever, Works Connection: Elite Perch, EZ Holeshot, Radiator Guards, Frame Guards, Lightspeed Carbon: Skid Plate, Front Disc Guard, Rear Caliper Guard, Brake Line Guide, Driven Shift Lever, Powdercoated: Engine, Calipers, Master Cylinders in Wrinkle Black, Frame/Subframe and Hubs in Transluscent YZ Blue, and Swingarm in Gold Flake. Renthal Moto Handguards, DecalWorks T8 Graphics in RM Yellow, LT Blue, and YZ Blue with YZ Blue Backgrounds. FinksyLizard Racing Gripper Seat Cover in YZ Blue. Ti Swingarm Bolt, Engine Bolts, and various washers.
Type of fuel: Sunoco GT100 and Bel-Ray H1R
Type of Premix/Ratio: 32:1
Type of Trans oil: Bel-Ray Gear Saver 75w
Type of riding(MX, trails/technical, desert ect): Night MX/SX/AX
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): Mid-Top, Wide Open, although my engine is tuned to hit down low it pulls that much faster to the top.
Front Tire: Dunlop Geomax MX31
Rear Tire: Dunlop Geomax MX51
Gearing (sprokets): 13/50 ProTaper Chain/Sprockets
Degree of satisfaction: 9.5
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: 2)LITTLE
Notes: The bike's fairly new to me in it's current state after I dumped a lot of work and money into it, but it hauls the mail and reliably. The jetting is spot on. It's my 250B bike of choice.
RM Year: 2005
RM engine size: 250
Carb mods: Stock
Air Filter (stock)
Main jet: stock
Pilot Jet: stock
Air screw: 2 turns out
Altitude where you ride: 2,000 ft
Temps: 70-90
Reeds: power reeds
Pipe/silencer: stock (repacked)
Head mod: slightly modified (touched up)
Other mods(FWW, ect.):decked out motor
Type of fuel: 93 oct mix
Type of Premix/Ratio: bel ray mc1
Type of Trans oil: atf f
Type of riding(MX, trails/technical, desert ect): woods
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): top end ripper
Rear Tire: maxxis IT
Gearing (sprokets): stock
Degree of satisfaction: very satisfied
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: no spooge
RM Year: 1981
RM engine size: 465
Carb mods(PowerNow, Wings, JDJetting, ect..): Had idle screw put in.
Air Filter (stock?) Stock filter with air vent holes drilled in airbox cover.
Main jet: 310
Pilot Jet: 45
Needle model/Clip position: Stock needle/Top position.
Air screw: 1.5 turns out
Altitude where you ride: 3000'
Temps: 35-85
Reeds: The engine has case induction. I can't remember if I ever put in aftermarket reeds.
Pipe/silencer:Answer aluminum silencer with a Sparky.
Head mod: None.
Other mods(FWW, ect.): 3.7 gal desert tank.
Type of fuel: 91 pump gas.
Type of Premix/Ratio: Yamalube/ 32:1
Type of Trans oil: Varies.
Type of riding(MX, trails/technical, desert ect): Desert
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): Everywhere
Rear Tire: Still has stock tires. I think it's a Dunlop. Don't remember the size, probably 4.60/18 or 5.00/18.
Gearing (sprokets): Stock gearing. Don't remember the number of teeth.
Degree of satisfaction: For a 30 year old bike I really can't complain. It runs rich in the midrange but I can't find a replacement needle jet that will fit this carb.
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: Medium.
Notes:
RM Year: 2004
RM engine size: 85
Carb mods(PowerNow, Wings, JDJetting, ect..): PWK28 swap
Main jet: 135
Pilot Jet: 45
Needle model/Clip position: 2nd
Air screw: 2 out
Altitude where you ride: 1250
Temps: 90-110
Reeds: Vforce3
Pipe/silencer: FMF SST, Shorty
Head mod: Ported for mid-top
Other mods(FWW, ect.): Vortex Ignition
Type of fuel: VP 4.4
Type of Premix/Ratio: Klotz 26:1
Type of Trans oil: MTL
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): Wide-open, is there another way?
Rear Tire: Michelin Med-hard
Gearing (sprokets): 14/48
Degree of satisfaction: Runs great, still tweaking
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: 2-3
Notes:
RM Year: 2005
RM engine size: 250
Carb mods: Stock
Air Filter twin air
Main jet: stock
Pilot Jet: stock/doma/vh (vanhasselt) like the vh the most, then stock, then doma
Air screw: 1 3/4 turns out
Altitude where you ride: sealevel
Temps: 5-30°c
Reeds: stock reeds
Head mod: stock
Type of fuel: 95/98 pump
Type of Premix/Ratio: putoline / 33:1
Type of Trans oil: 10w40 housebrand
Type of riding(MX, trails/technical, desert ect): hard and sand tracks
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): mid to top
Gearing (sprokets): 13-49
Degree of satisfaction: satisfied, think i'll go for a heavier gearing like 14-50
Edited by welink
RM Year: 2006
RM engine size: 250
Carb mods(PowerNow, Wings, JDJetting, ect..): none
Air Filter (stock?)Twin Air/ NoToil
Main jet: 168
Pilot Jet: 48
Needle model/Clip position: NECJ 3
Air screw: 1
Altitude where you ride: sea level
Temps: 45-100
Reeds: stock
Pipe/silencer: stock, one more dent and it will be a PC Works/Fact. 304
Head mod: none
Other mods(FWW, ect.): SDG seat, RC high bend FatBars, Pillow tops
Type of fuel: 93 octane
Type of Premix/Ratio: Suzuki Super2 @ 30:1
Type of Trans oil: Suzuki 10w-40
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): I use it all!
Little to no spooge.
Notes:
RM Year: 2006
RM engine size: 2fitty
Carb mods(PowerNow, Wings, JDJetting, ect..): Boy Reed Cage
Air Filter (stock?): No Toil performance filter
Main jet: 168
Pilot Jet: 52
Needle model/Clip position: 3rd
Air screw: 1 1/2
Altitude where you ride: 3-6k
Temps: 30F-100F
Reeds: Boyesen
Pipe/silencer: FMF
Head mod: None
Other mods(FWW, ect.): EVO suspension
Type of fuel: 93 Pump
Type of Premix/Ratio: Bel Ray H1R - 40:1
Type of Trans oil: Bel Ray Gear Saver - 85w
Type of riding(MX, trails/technical, desert ect): MX and GP's
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): Pinned
Rear Tire: D756 (If I can find them, I buy them still!)
Degree of satisfaction: 8 out of 10
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: Zero/none
Notes: Bike is a blast to ride, just bought it used, so it had some issues. Lost a piston after only riding about 10 hours on it. It has a noisy clutch that bothers me at times. Performance wise - A+ though!
  • 4 weeks later...
RM Year: 2005
RM engine size: 250
Main jet: 170
Pilot Jet: 48
Needle model/Clip position: NECJ-5
Air screw: 1.5ish
Temps: 60-90F
Reeds: V-Force III
Pipe/silencer: FMF Gnarley & Titanium II
Head mod: none
Other mods(FWW, ect.): 10oz FWW, full hinson clutch assembly, porting, 18" rear, WER damper, CCycle suspension
Type of fuel: 93 pump
Type of Premix/Ratio: Maxima Super M @ 32:1
Type of Trans oil: Havoline 10w-40
Type of riding(MX, trails/technical, desert ect): Trails (singletrack)
Where in the powerband do you ride (Lugger/Bottom End, or Wide Open - Top End): mostly bottom & mid
Rear Tire: MX51
Degree of satisfaction: 10/10
Very little spooge
Notes:
I love this bike, spent years dialing it in for me. Its perfect.
