removing left side cover ????
2 replies to this topic
  • barbwire44
Posted May 11, 2011 - 03:59 AM
Any tips or tricks to getting the left side cover off, am replacing the timing chain and need to get the mag off. Have removed all bolts from outer cover but seems to be stuck around the starter??
thanks
  • 10wr450
Posted May 11, 2011 - 06:31 AM
thanks
you have to remove the cover on the starter torque limiter(round cover with two bolts) then remove the torque limiter and there is one more bolt under it that holds the left side cover on.:thumbsup:
  • barbwire44
Posted May 11, 2011 - 08:23 AM
Appreciated thank you.
