WR426F Grey wire mod and jetting?
4 replies to this topic
  • gawarrior
Posted August 20, 2003 - 12:17 PM
I have already taken off the airbox lid. Will take out the spark arrestor when I am not in National Forests etc. I am considering doing the grey wire mod. But I do not know much about rejetting the carb. If I do the grey wire mod will I need to do any rejetting or can I leave it with the stock setup? I am afraid to start messing with the carbs because I may screw it up and not get it back right. If I have to reject I may not do the grey wire mod on my 02 WR426F
Thanks for the help
  • Rich_in_Orlando
Posted August 20, 2003 - 12:51 PM
You don't need to rejet if you do the gray wire mod. Good luck taking out the spark arrestor. It's welded to the muffler endcap.
  • gawarrior
Posted August 20, 2003 - 12:56 PM
The spark arrestor in mine just has a small bolt holding it in. Take the bolt out and the spark arrestor pulls right out.
  • WRSTEVE
Posted August 20, 2003 - 02:19 PM
You are talking about the baffle, not the spark arrester :D
To take out the spark arrester, you would remove the 3 bolts on the end of the muffler :)
  • gawarrior
Posted August 21, 2003 - 12:12 PM
Oh, my bad. I guess then to take out the spark arrestor it is welded in.
