WR Start Button
8 replies to this topic
  • Junior_Vet
Posted August 19, 2003 - 08:48 PM
OK. I've searched and can't find this topic anywhere. This weekend I happily used my electric start many times during a Hare Scramble. Once I went through the final check, I stopped the bike to talk. When I went to start it again (with the button) the grey button was missing. :D
It looks like it was riped out of the rubber boot that surrounds it on the switch. I assume that a passing tree branch some how ripped it out but the switch is positioned so the button is facing backwards.
Is this just a freak occurance or has it happened to anyone else?? :)
The parts guy says I have to buy the whole switch for $60 (CDN $). Anyone have any other suggestions? KTM switch? Others?
  • crushedreams
Posted August 19, 2003 - 09:10 PM
I just happen to have one that I took off.
Ill send it to you. PM me your address. FREEBIE
  • Beta_Man
Posted August 19, 2003 - 10:26 PM
the same thing happened to me but it was the kill switch. Every thing was there except the middle part. I just switched it with the older style and it seems to be alot more sturdy. Although i would doubt you would want to do this with the starter button.
  • TWSimpson
Posted August 20, 2003 - 03:08 AM
Mine did the same. Had to replace the whole switch. :D If this one doesn't last, I'm going to look for a heavy duty replacement. :)
  • ddialogue
Posted August 20, 2003 - 04:18 AM
I had the same thing happen with my kill switch. It got caught in one of the air vents on my chest protector when I got too far up over the bars. I replaced it with an older style switch; problem solved. I haven't had a problem with the start button yet...
  • RichBaker
Posted August 20, 2003 - 03:58 PM
It happened to me 1st ride.....stalled in a wash and went to start her and there was no button! Had to kick her the rest of the ride. When I got home I pulled the kill sw. off my 90 YZWR and spliced in the new connector....works great and is out of the way compared to the stocker. Haven't lost it in 6 rides....
  • Junior_Vet
Posted August 20, 2003 - 04:49 PM
Seems pretty common. Thanks for the responses. I bet it was chest protector too! I'll have to look for a better switch like an older kill switch. I did notice that a 450 EXC has a dual switch (starter and kill) in the same unit without the rubber surrounding the switch. That might be an option to clean up the handlebars?
  • KiwiThumper
Posted August 21, 2003 - 05:08 PM
The KTM style one comes standard on the AU/NZ bikes (complete with all the Dual Sport stuff) I have removed mine as the kill switch starts getting really "sticky" probably from sand and sheeiiit. In the end, if I used it, I would have to flick it several times to get it to return to the fully ejected position ...
I am using the "off road" kit with the same witches as you guys and havent had a problem yet ...
Cheers Deano
  • Junior_Vet
Posted August 22, 2003 - 08:13 AM
Good to know. Isn't this board great? :)
