2005 wr450 carb parts
5 replies to this topic
  • strtdsmallproject
Posted May 02, 2011 - 04:46 AM
Im having some float issues and cant find part numbers for the float needle seat. I was wanting to change the seat along with the needle.
  • Just_a_trail_rider
Posted May 02, 2011 - 10:16 AM
You may not find that in the Yamaha parts catalog.
look at Sudco. Or, just call them. They got the stuff that you can't get directly from Yamaha.
www.sudco.com
  • strtdsmallproject
Posted May 02, 2011 - 01:06 PM
sudco says that the seat is not removeable. Its real hard to believe. I just changed the seat and needle out on my buddys 426 and that carb looks almost the same minus the hot start on the side of the carb.
Posted May 02, 2011 - 07:58 PM
That seat is brass, isn't it?
Someone, somewhere should have that. I remember asking Sudco about that two years ago for my 450 and they told me it was available. Do you think they were referring to the seat for the 426 carb instead?
Another question, why do you think that the seat needs to be replaced? Is gas leaking past the float needle? Is there a "thicker" one available?
  • William1
Posted May 03, 2011 - 03:55 AM
Try CarbPartsWarehouse ot KTM or Cyclewearables
No no 'thicker' seas are made, it would only force you to reset your float height anyways, negating the extra thickness.
Usually a leak at the seat is caused by the oring there having dried out and cracked. The needle seat very, very rarely needs replacing.
  • strtdsmallproject
Posted May 04, 2011 - 06:01 PM
I agree, i was just gonna change it while i was back in the carb. Im gonna just get a new valve needle and see if it fixes it. I figured while i had the carb out and starter out i would just replace. starter is comming out for new brushes. Thanks for reading and offering all the help
