Coolant Coming Out
3 replies to this topic
  • Big_Al
Posted May 07, 2001 - 08:02 AM
Thers a tiny hole at the bottom of my water pump housing, when I first fire up it drips coolant, what the hells that all about?
  • Guest_Guest_*
Posted May 07, 2001 - 03:53 PM
Big Al, The hole lets you know when the seal is going bad, so if it leaks out that hole you better order a pump A.S.A.P. ~Hit-man~ (Cars are the same way)
00' yz426f LATER DAYS!!!
  • Maicoman
Posted May 08, 2001 - 06:32 AM
Big Al
Because I have never replaced the YZ seal,
I am not sure if YZ's are the same as CR's, but on certain CR's you can fix the "peep hole " leak buy simply replacing the outer water seal, that is just behind the impeller.
Hit-Man
do you need to change the entire pump if the seal (s) are bad ?
  • Guest_Guest_*
Posted May 08, 2001 - 09:42 PM
Mine did that last winter when I went out for a ride.
I had left the bike towards the front of the garage near the door where it is noticebly colder. I think this is what caused it.
the seal must have gotten real cold or maybe the cold air dried it out.
I was out riding and thought i had cracked something. It was the only time i did not have my manual in my toolbox............figures!
got home and ordered the $2.13 part and also the oring gasket was about$4 which i replaced also.
but anyway i was happy it was only $6 instead of $600
Super simple too.
just make sure you put it in square.
I used just a little tiny scrwdrvr to get it out very carefully.
I used a socket that was the right size to push it into place.
G4
.It is actually called the WEEP HOLE
NOPE..........BOY.......
That's not thunder ridin' your BUTT .........
It's a whole Damn HURRICANE!!!!!!
[This message has been edited by g4racing (edited 05-08-2001).]
  • Hot  28 replies
  • 9 replies
  • On Yesterday, 06:20 PM
  • 0 replies
