81' xr200r sprockets
5 replies to this topic
  • VwDetour
Posted April 28, 2011 - 02:59 PM
G'day!
Time to replace my chain and sprockets, I've got stock gearing of 13/50 with an 18" wheel, and I'd like to go to 12/51.. BUT looking through my local suppliers catalog they only stock the front OEM sprocket, and this is not the size I would like.
SO my question is... what sprockets from different bikes are compatible with my 1981 XR200R. Also any comments or experiences about changing the gearing to 12/51 on 18"?
P.S. The chain i'm ordering is an o-ring 520 with 110 links (stock is 520-106) I imagine with the new gearing it won't be that huge of a change to necessitate more than 110 links. (Want to make sure so I'm not out $80 and have a useless chain)
Sorry for my bad English, I'm Canadian :thumbsup:
  • VwDetour
Posted April 28, 2011 - 04:53 PM
Okay I've found out that the following bikes have the same countershaft spline as my 81 xr200r:
Honda - ATC200X 1983
Honda - ATC200X 1984
Honda - ATC200X 1985
Honda - CB250 Nighthawk 1991
Honda - CB250 Nighthawk 1992
Honda - CB250 Nighthawk 1993
Honda - CB250 Nighthawk 1994
Honda - CB250 Nighthawk 1995
Honda - CB250 Nighthawk 1996
Honda - CB250 Nighthawk 1997
Honda - CB250 Nighthawk 1999
Honda - CB250 Nighthawk 2000
Honda - CB250 Nighthawk 2001
Honda - CB250 Nighthawk 2002
Honda - CB250 Nighthawk 2003
Honda - CB250 Nighthawk 2004
Honda - CB250 Nighthawk 2005
Honda - CM250C 250 Custom 1982
Honda - CM250C 250 Custom 1983
Honda - CMX250C Rebel 1985
Honda - CMX250C Rebel 1986
Honda - CMX250C Rebel 1987
Honda - CMX250C Rebel 1996
Honda - CMX250C Rebel 1997
Honda - CMX250C Rebel 1999
Honda - CMX250C Rebel 2000
Honda - CMX250C Rebel 2001
Honda - CMX250C Rebel 2002
Honda - CMX250C Rebel 2003
Honda - CMX250C Rebel 2004
Honda - CMX250C Rebel 2005
Honda - CMX250C Rebel 2006
Honda - CMX250C Rebel 2007
Honda - CR125R 1982
Honda - XL200R 1983
Honda - XL200R 1984
Honda - XL250R 1984
Honda - XL250R 1985
Honda - XL250R 1986
Honda - XL250R 1987
Honda - XR200 1980
Honda - XR200 1981
Honda - XR200 1982
Honda - XR200 1983
Honda - XR200 1984
Honda - XR200R 1981
Honda - XR200R 1982
Honda - XR200R 1983
Honda - XR200R 1984
Honda - XR200R 1985
Honda - XR200R 1986
Honda - XR200R 1987
Honda - XR200R 1988
Honda - XR200R 1990
Honda - XR200R 1991
Honda - XR200R 1993
Honda - XR200R 1994
Honda - XR200R 1995
Honda - XR200R 1996
Honda - XR200R 1997
Honda - XR200R 1998
Honda - XR200R 1999
Honda - XR200R 2000
Honda - XR200R 2001
Honda - XR200R 2002
Honda - XR250R 1984
Honda - XR250R 1985
Honda - XR250R 1986
Honda - XR250R 1987
Thought I would post what I found incase someone else ran into the same problems. I still need some info on the rear sprocket if anyone can lend a hand; I've decided to keep the stock gearing as it is already geared incredibly well for tight woods, But I have yet to find a different bike with the same rear sprocket setup :thumbsup:
Edited by VwDetour, April 28, 2011 - 05:11 PM.
  • Chuck.
Posted April 29, 2011 - 02:00 PM
As your list shows front sprockets from almost an any 200cc 2 valve motor will fit.
JT lists a 12 tooth for the front, check the TT store. JT also makes a rear 50 but I don't know if it is alloy or steel. I recommend using the Honda clip (bolts to the sprocket) to position the sprocket on the counter shaft instead of the aftermarket clip, less chance of the chain wrecking the case. Also I don't recommend using an "O" ring chain because they are wider than stock and can wear on the engine case. If you want a ringed chain I recommend DID 520VT2 because it is narrower than a regular "O" ring chain.
Rear sprocket is more difficult because there were two different hubs used on the 200s in the early eighties, the twin shock used a different hub than the mono-shock bikes. The difference between a 50 and a 51 is only 2% so I don't see the need for a 51. The cheapest gear reduction will be switching to a 12 tooth counter shaft sprocket. I've run 12/49 with an 18" rear tire on several XR200s thru the years with good results. 110 links should be long enough for almost any sprocket combo that will fit the bike.
  • VwDetour
Posted May 02, 2011 - 06:07 PM
Thanks for your help Chuck, although i'm in a bind again. I ordered a rear sprocket from an 81XR250R, which by the looks of the microfiche, should have been the same style of sprocket; I was wrong.
So I'm still at a loss on a rear sprocket, any other bikes that take the same style rear sprocket that anyone knows of? thanks.
  • Chuck.
Posted May 03, 2011 - 01:56 PM
My knowledge of early XR rear sprockets is limited except that they use a diabolical cush hub, also I think the 81-83 XR200R is unique 5 bolt sprocket, and the XR200 twin shock is a 4 bolt sprocket.
  • VwDetour
Posted May 03, 2011 - 03:55 PM
Problem solved (fingers crossed)... Went to another store and found a JT sprocket in their catalog.
Thanks again for your help
Top Speed of an XR200 by Yamiha
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • Hot  49 replies
Top speed of xr200r? And xr250r? by LukeSand
Dirt Bike   Make / Model Specific   Honda   XR250/400
  • 12 replies
Honda CRF100F 2017 by Chris.GVS
Honda CRF100F 2017
  • 0 reviews
xl100s vs xr100 trans difference? by CarmanCRF
93 honda xr100r by Honda fanatic
  • Hot  84 replies
