Gearing the WR 450
7 replies to this topic
  • cherrypicker7
Posted April 27, 2011 - 08:05 AM
A friend and I both are on 05 WR 450s, and we have some gearing issues, both feel that 1st gear is a bit high and 5th isn't high enough. I have had some problems stalling the bike and have recently installed a Revloc Dynaring to see if that problem is solved. But sprocket changes will only make 1st even higher if we want to get more speed at lower rpms. Not sure there is much to be done, don't even know if alternative gearing is available, I don't want to go there anyway. Any thoughts? Sure wish these motors came with a 6 speed.
  • WRF Woods Weapon
Posted April 27, 2011 - 09:00 AM
Same here...It's funny when you are riding and you forgot that you have tapped out every gear and you are shifting for another, when there is none...something about speed and power that we don't deny our adrenaline...we more more!
  • Just_a_trail_rider
Posted April 27, 2011 - 10:48 AM
if you are stalling, you should be lowering your gearing a bit.
You must be pretty fast if you are riding tapped out in 5th. :thumbsup: The WR's have a very respectable top end.
  • homer2000
Posted April 27, 2011 - 01:25 PM
I do it all the time go through the gears and im already in 5th, 6th gear would be great
  • cherrypicker7
Posted April 28, 2011 - 07:00 AM
No, I don't often run at top speed, but I much prefer to run anywhere from 50-65 on fireroads or paved and I don't like to run at the higher rpms required. There really is no solution other than splitting the cases and changing the gearset, and I don't care to make the effort. I think, the stalling issue has been taken care of with the Dyna Ring
Posted April 28, 2011 - 11:06 AM
I don't know if yo have any options on tranny gears for the wr. That's as wide as they get.
Maybe you can go big bore on the cylinder and have a bit more grunt to run the taller gears.
btw... how do you like that dynaring?
  • woods-rider
Posted April 28, 2011 - 11:30 PM
I would also love a 6th gear. I ride 100% off road, but some desert areas have LONG straights that I could comfortably go another 20mph if my bike could do it (without reving the piss outta it).
  • cherrypicker7
Posted April 29, 2011 - 03:00 AM
As for the Dyna ring, I certainly liked the install, very easy. So far it has worked as advertised, but I haven't had much of an opportunity to try it out, other than a few spins around the farm. As I mentioned the reason I went for it, was the anti-stall feature, and so far that is working. I seldom use the clutch, only when starting out and in certain technical sections.
