Wideband for 2-stroke tuning??
1 reply to this topic
  • Soul Man
Posted April 26, 2011 - 09:13 AM
I know the oil will shorten sensor life. I want to hook one up just to get jetting set and then remove the sensor.
Anyone do it on 2-strokes?
How long will the sensor last (enough to tune 3-4 bikes? of just doing test runs)?
Where to put sensor: in expansion chamber? Pipe leading to muffler? (have spark arrestors, so sticking a long tube in the muffler won't work).
If it would work, is my assumption correct in that you would:
Ride at steady 1/4 throttle to determine pilot
Ride at steady 1/2 throttle to determine needle
Ride at WOT to determine main jet?
Spoke to a guy at Daytona Sensors, he said sensor would last in the "tens of hours" which should be plenty to sort out a few bikes, but he didn't really have any real info on 2-stroke tuning.
  • William1
Posted April 26, 2011 - 12:45 PM
Before the sensor is installed to test, have the bike fully heated, remove the bung, insert the sensor and get your numbers. A sensor will last about five hours of run time.
Pilot is idle
Needle is at 0 to 1/8, 1/8 to 1/4, 1/4 to 3/8... up to 7/8
Main is WOT
Do it on a dyno. If you try to do it by riding, you will kill a sensor doing one bike. You have to do your tests on an incline, in fourth gear and it must be repeatable.
There are a few good threads in this forum that talk about widebands and 2S. Do a search.
