Dodgy Indicators
2 replies to this topic
  • 4xsama
Posted April 25, 2011 - 09:27 PM
I've just re-connected the indicators on my '05 WR450R and the don't tick on and off as usual. They light up, stay off for a bit, then might come on after a while.
Any ideas on the cause?
Cheers
  • MANIAC998
Posted April 26, 2011 - 04:13 AM
Bad connections would be my guess. Probably some corrosion going on. Check all connections, and use some di-electric grease on those connections to keep corrosion at check. Maniac
  • djrevz
Posted April 26, 2011 - 12:44 PM
hi, the problem there is most probably that the relay has packed up.... before buying another... get a voltage meter and put the black wire to the earth on the plug that connects to the relay and the red to the live and see if it gives a constant on off voltage reading if so the relay is fine but very unlikely...
