Help with auto clutch
1 reply to this topic
  • okietech
Posted April 23, 2011 - 06:50 PM
Would like an auto clutch fo a yz400f 98 model. Problem is nobody makes one. Can I use 426 parts to make one work.
Posted April 23, 2011 - 08:28 PM
You should search this a bit, or wait to have someone more familiar with part interchangeability between the two models, but I believe a 426 clutch will fit if the right crankcase cover (the cover, not the crankcase half) and the clutch cover are changed to make room for it. You'd need a 426 basket/gear assembly (use an '01/'02 so you can get "stuff" for it). Are you sure you want to spend ~$800 on this deal for a 400?
  • Hot  36 replies
  • Hot  50 replies
  • Hot  38 replies
