akarob said:
Your carb is also known as a "horizontal". It's pretty much the same carb that comes stock on all the 4 stroke KTMs - except that most of the KTMs use a 39mm, you got the 41mm. Nice call.
Where's all your vent hoses? There should be 4, plus one small bowl overflow hose. Here's a picture of mine. I just happen to have it off the bike right now. (I know my accel pump shaft is out, I just put the bowl on real quick to do a thorough cleaning)
Good luck with your jetting.
the white arrows point to the ONLY two vent lines on this carb and there is NO overflow...I thought that was odd also.
also thanks for the jetting resources, :banana:
NW ADV said:
I have one on mine, and the Sudco jetting was waaaay off. I think I am in the 145 range for main, forget on the pilot. Contact "Burned" here, he gave me specs that were dead-on.
How did you get a choke? Wish I did that!!!!
BP
I had read from another member that it was a option to get the choke, you just have to request it with your carb when ordering, it doesn't show up as a option when looking at the kit.
I went through a dealer where I get 10% off and just instructed him to be sure to request the choke when he ordered it.(its going to be $63-$82 more depending on who you talk to) the 10% off just about covered the extra cost of the choke.
zx12r said:
how are you deciding your jetting is lean? i have a FCR-MX 40mm on my XRL. live at a 1000ft ride up to 4000ft and my jetting is, mj 168, pj 45 , and mine runs great.
for the choke knob, i found a piece of rubber hose that fit snugly over the knob to lengthen it. the hose comes out just under the gas tank and i can just reach down to pull it on and push in for off, works great.
"how are you deciding your jetting is lean?" -because first the bike was surging horribly when I putted out of the driveway, then the idle would hang when I let off the throttle,the bike was falling on its face off idle to just under 1/4 throttle, when I increased the fuel screw the bike ran better and then after turning in my pilot AIR jet the bike ran even better, but didn't clean it up, I have only been riding around town at 350ft elevation and I bet the bike would run better at higher elevations unless the main jet was too much...hence the ongoing tuning of this carb, but thanks for the idea of adding the rubber hose to the choke knob as I thought of this as one option and it's good to know that it is working successfully for you.:ride:
