Shock Collar
4 replies to this topic
  • Danger16
Posted April 22, 2011 - 10:26 AM
Sorry if this is obvious and I'm using a poor search technique, but I'm trying to find out the best way to gain access to the shock collar to adjust the preload and set the sag on a 2009 YZ 450. It is not easy to get to the shock collar. I'm also interested in what to use to move the ring, I'm assuming a long screw driver / punch and a hammer?
I traded my 2008 KTM 250 SX for this bike and am going through the whole bike to get it set-up for hare scrambles.
Posted April 22, 2011 - 11:11 AM
It's a pain in the butt. But DON'T use a screwdriver. You'll cut the lock ring. Find a piece of brass or aluminum rod or 1/4x1 scrap and use that. Once you have the lock ring loosened, you can reach under the air box and turn the adjuster by turning the bottom of the spring (if the bike is up on a stand).
Or, you could go this way:
http://www.thumperta...ad.php?t=881489
  • crf450319
Posted April 22, 2011 - 11:54 AM
I set my shock up initially for my weight after I installed a 5.9 DSP spring in it, and have had the shock apart a total of 5 times. I've used a screwdriver every time and haven't cut my lock ring.
April 30/10 Fork oil (both chambers) and shock fluid replaced @ 10.2 hrs
June 18/10 New fork & shock springs, replaced outer chamber oil in forks @ 20.3 hrs
July 21/10 Fork oil (both chambers) and shock fluid replaced @ 30.8hrs
Sept 30/10 Fork oil (both chambers) and shock fluid replaced @ 50.5 hrs
April 21/11 Fork oil (both chambers) and shock fluid replaced @ 70.3 hrs
Tightening up the spring I do by hand, when the shock is on my work bench. I'd think it might be a little tricky if it was in the bike but worth a try ? I used the hammer & screwdriver method when the shock was in the bike.
  • SAthump
Posted April 22, 2011 - 05:51 PM
I have a 1/4 steel rod I put a small joggle in, fits nicely between airbox and reservoir, and from the front by the carb.
  • curtis515s
Posted April 23, 2011 - 11:21 PM
Motion Pro just came out with a shock spanner punch. It has a brass tip and it works great.
http://www.motionpro.../partno/08-0483
  • Hot  113 replies
  • 3 replies
  • On January 15, 2017
