Enduro Bash Plate for 03 wr450
6 replies to this topic
  • 450wr03
Posted April 18, 2011 - 08:18 PM
hello i want too update my skid plate on my wr and was wanting to know witch make is the best. I have the works connection plate but i want one with the ears on it to protect the engine on the sides. I see some that use clips around the frame are these good ones or are there ones out there that just uses the bolts from factory. I see some on ebay that look like they would need some holes drilled in them for cooling and to get the mudd out. Thanks
  • MANIAC998
Posted April 19, 2011 - 03:31 PM
My '06, which has the same frame as yours, uses the Yamaha GYTR, and it bolts right up to the existing frame mounts. It has the "ears" on the sides just like you want. Maniac
  • 1trackmind
Posted April 20, 2011 - 07:43 PM
I've got an 03 that I am running the "Ricochet" skid plate from Rocky Mountain. I don't know how it compares to others but it is pretty thick. It uses claps on the frame. I can't remeber if it uses any of the stock bolt holes or not.(I think it does.)
Anyway, it has saved my case taking a couple of hits that could have been fatal.
My .02
  • miweber929
Posted April 21, 2011 - 03:53 AM
My .02
+1 for Rocky Mountian. They make basically everyone's for them (Moose, Devol, etc.) and make a good product.
  • bg10459
Posted April 21, 2011 - 05:46 AM
I have abused the hell out of my GYTR plate and it still functions as per normal. Easy install, too.
  • 450wr03
Posted May 24, 2011 - 05:58 PM
Well i bought the GYTR skid plate for my bike and went to bolt it up but it doesnt bottom out when tightening it up. Do you guys put washers or something in there ? Also do you take off the original side ears that bolt to the frame? Thanks
  • MANIAC998
Posted May 24, 2011 - 07:20 PM
Yes, remove the stock side ears before installing the GYTR plate. And yes, I've added washers between the plate and the frame at both the very top and the very bottom of the plate. This allows you to tighten the bolts completely, securing the plate. Maniac
