WR450F Transmission?
4 replies to this topic
  • yz449f
Posted April 18, 2011 - 08:36 AM
this is my first post and yes I tried searching so forgive me if its been discussed. I have a 2007 YZ450F thats in supermoto trim, the third gear shift fork is bent and it needs to be repaired. No big deal, I want to know if the WR trans will fit? I know the cases, shift drum and one of the two shafts are the same, the other shaft the part number prefix is different but everything else matches fine. I think it will work and I know the wider ratios would be a bit better for me. Thanks for the help and I look foward to spending some time on this site :thumbsup:
Posted April 18, 2011 - 09:33 AM
Did you try reading the thread at the top of the index that says, "look here first"?
http://www.thumperta...ad.php?t=464212
  • yz449f
Posted April 19, 2011 - 07:43 PM
Guess it helps to read! Thanks for the link its seemingly a painless swap
Posted April 19, 2011 - 08:08 PM
It's a direct bolt-in. The best part of it is that unlike the 4 speed models, you don't need absolutely everything. The cam, forks, and output shaft from the YZ can be reused.
  • yz449f
Posted April 19, 2011 - 08:22 PM
Awesome, I can wait
  • Hot  30 replies
  • Hot  36 replies
  • Hot  50 replies
  • Hot  38 replies
