Quick Help/Idea Needed
3 replies to this topic
  • Dodger
Posted August 13, 2003 - 03:34 AM
Last night I was doing an oil change on the bike. Started it up, let it idle for a minute, and decided I should wash it off a bit before undoing the plugs. After a quick spray down, I started it up again, and now have a very noticable ticking sound coming from the engin :). What could have happened??? I know cold water on a warm engine isn't totally desireable, but I just can't imagin it would cause problems. I've run glacial run off streams with the bike super hot many times with no problems.
Any ideas as to what it could/might be?? I'll be checking it again when I get home tonight.
Dodger :D :D
  • holeshot426
Posted August 13, 2003 - 05:15 AM
I have heard that before also, I dont know what it is but I was alarmed the first time I heard it to. It was about the same scenario, I was starting it after washing it. No worries, just noisy valve train sometimes. Like you said, there is no difference between that and running through ice cold streams in winter. :)
  • chopper357
Posted August 13, 2003 - 06:39 AM
was the bike on or off when you heard the "ticking noise"?
  • Dodger
Posted August 13, 2003 - 08:04 AM
Running. The ticking was in unison with the piston, and was definately a brand new noise than the bike had 2 minutes earlier..........
Dodger :) :D
