Throttle stop on '98 400
4 replies to this topic
  • sathumper
Posted August 12, 2003 - 11:51 PM
Hi all,
I have been reading posts for a while now and all of you have mentioned shaving the throttle stop. I am in South Africa and at an altitude of 5800 feet asl. Do you recommend shaving the stop and if so what jetting should I go to. Bike is currently stock apart from a Pro Circuit T4 pipe.
Thanks in advance
  • holeshot426
Posted August 14, 2003 - 12:46 PM
You should cut the throttle stop if you want more throttle, plane and simple. For better breathing, you can remove the air box lid. Free mods are just that - free :)
  • lewichris
Posted August 14, 2003 - 01:43 PM
i dont think that you would have to rejet after cutting the throttle stop. Shoot riding your bike areound with a Pro Circuit pipe at basically idle must suck. i bet your throttle stop is already cut.
  • sathumper
Posted August 20, 2003 - 03:16 AM
Cheers guys thanx for I should check to see if the stop has been shaven ?.....suggested length to look for ?
Thanks in advance
  • MOmilkman
Posted August 20, 2003 - 05:41 AM
Take off enough of the stop so that 9mm remains from the head of the bolt to the end.
