WR 400 PROBLEMS RE START
6 replies to this topic
  • GSS
Posted August 12, 2003 - 08:15 AM
I am new to the list .
Just bougth a 99´WR 400 havent ride it yet , i keep hearing comments that this bike has trouble re starting when hot , its this true ? if so , any tips in solving the problem ? Thanks in advance for your advice ,
George
  • MOmilkman
Posted August 12, 2003 - 08:17 AM
No. My bike has never been hard to start. Its just a technique you need to learn. If the valves are adjusted properly you shouldnt have any problem fireing her up. :)
  • jchantzWR400F
Posted August 12, 2003 - 08:19 AM
I have never heard of having problems while re-starting the 99WR400 while hot.
In fact, the only time I pull my hot-start switch is after I stall it on a hill, or lay it down. My rule of thumb, is only use the hot-start when you smell gas.
  • James_Dean
Posted August 12, 2003 - 08:23 AM
Use the hot-start button on the carburetor when restarting a hot engine and don't turn the throttle. Every time you turn the throttle the accelerator pump squirts fuel and will flood your bike quickly (the biggest mistake for new riders here).
For your cold-start procedure, turn the throttle 1 or 2 times to squirt fuel and prime the engine. Then don't turn it again until the bike is running.
James
  • ZEKEDAWG
Posted August 12, 2003 - 12:19 PM
Only had to use the hot start on 90 + degree days when I have stalled after extended periods of slow riding. Other than that 1-2 kicks every time. The starting procedure scares off more people than it should IMO.
  • holeshot426
Posted August 12, 2003 - 01:57 PM
:cry:No worries, once you get the technique figured out, you will never buy anything but blue...
  • GSS
Posted August 13, 2003 - 04:08 AM
Thank U ALL for your kind replies.!!
George
