2011 yz450f doesnt shift right
14 replies to this topic
  • sandcar361
Posted April 11, 2011 - 03:49 PM
Anyone having issues with the new 450 not shifting right? Mine has a hard time going to neutral and even a harder time shifting thru the gears. Maybe its just me or maybe I havent given it enough break in time?
  • moto278
Posted April 11, 2011 - 04:14 PM
it goes away with more break in time. 10's had the problem too
  • Chazmagnum
Posted April 11, 2011 - 04:54 PM
Yup give it time. The tranny is solid!
  • brentn
Posted April 11, 2011 - 05:22 PM
I still can't find nuetral about 90% of the time when the bike is running!! Once in a while I get lucky when coming to a stop, but usually I'll kill the bike and then all of the sudden it just pops right in no problem.
I figured it would be a break in thing, but it appears that it is not since I have 28 hours on the bike.
  • Davey762
Posted April 11, 2011 - 07:27 PM
My 2010 has a hard time going into neutral while running as well, this is kind of a pain but also potentially good because it prevents hitting neutral while riding hard.
  • Chazmagnum
Posted April 11, 2011 - 07:32 PM
I'm at 60 hrs and it's coming around now. But yeah it took a while.
:cheers:
  • brentn
Posted April 11, 2011 - 08:12 PM
One thing I don't like is when we come to a stop on the trail and I'm dicking around with the shifter trying to find nuetral. We might sit for a minute or two and I have the clutch dis-engaged the whole time, just adding to the heat of the engine, and possible slight wear on the plates. The minute stops are usually too short to hit the kill switch..
Maybe I'm just lazy :cheers:
On another note is that shifting on this bike is really really tight and there is no sloppiness especially when you compare it to older bikes. I've only ridden other used bikes (yz250's and 125, 00, 01, 03 and 05) and all the trannsmissions feel the same. The shifter feels very 'sloppy' in comparison with large gaps when moving the shifter and feeling the gear engage. On the 2010/11 it's much much tighter, it was one of the first things I noticed when I got the bike. Thought I read that it was a new feature as well... Can't remember.
Point being, maybe this is a consequence to having a tight transmission, finding nuetral is harder?
Just guessing at this point :ride:
  • sandcar361
Posted April 12, 2011 - 07:13 AM
I only have 5 hours on the bike so I will give it more time to come around. Thanks for all the quick replies. I need to get the suspension dialed in now.
  • yz450fcranker
Posted April 12, 2011 - 07:14 AM
go flat out a 1/4 mile at a time running through all the gears thats how i got my 09 to do better in all gears its like slicing butter with a butter knife you get somthing out of it the gears get conditioned
  • sandcar361
Posted April 20, 2011 - 08:31 AM
Ok I have another 6 hours on the bike and it starting to shift real good now. I was a little worried at 1st.
  • yz450fcranker
Posted April 21, 2011 - 11:58 PM
yamis are like good tires they are not good until they get a first run
  • dodgydan
Posted April 26, 2011 - 11:00 AM
While you guys was having some probs shifting, did the bike have any "Clutch drag" issues?
as mine is and only when clutch is in, she will creep forward, untill i rev her abit then it sort of eases when revs are high, then back to drag on tick over?...
  • sandcar361
Posted April 26, 2011 - 11:30 AM
No clutch issues for me. Let us know what you find out about your clutch.
  • bsam450
Posted April 27, 2011 - 03:00 PM
One good thing too remember is that it is fuel injected and it starts on first kick every time. So enjoy your minute brake without the motor running.
  • Troutman
Posted April 27, 2011 - 07:06 PM
I had the issue with finding neutral as well at first. I found that I was not pulling the clutch as far as it needed to go with just my normal two finger pull. My other fingers on the grip were stopping it too soon. I adjusted the clutch at the bar and now it is fine, a little harder to pull at first but it broke in well after a little time. Just something to try first if you are having the same issue.
  • Hot  50 replies
  • Hot  113 replies
