How much PSI is good compression on a cr250?
8 replies to this topic
  • wht02cr125r
Posted April 11, 2011 - 12:30 PM
so i was wondering how much compression is considered to be a decent top end for a 02 cr250?
  • Blazinthetrails200
Posted April 11, 2011 - 12:33 PM
150+ should be fine anything below that would be low
  • Third-Reef
Posted April 11, 2011 - 02:06 PM
MY 97 had 180 cold with the old top end and stock piston. i just put in a prolite piston and i am getting 170 cold befor having run the bike. It wll be interisting to see what it is after i break it in and thry it warm.
  • Hairyyeti
Posted April 11, 2011 - 07:57 PM
Why change it?
  • Third-Reef
Posted April 11, 2011 - 08:35 PM
I have had my bike for 4 years and never touched the top end. If i was going to take it off, i was going to replace it. i measured the piston, and the diameter and ring grooves were right at the wear limits.
  • CRPilot
Posted April 12, 2011 - 09:30 AM
I was at 195: Fresh piston and rings, cold, with base cut and head/squish set up for race fuel on an 02.
  • Third-Reef
Posted April 12, 2011 - 07:34 PM
FYI on my 97 above where i got 170 with the new piston i checked and the squish was at .065". After i break it in and see how it runs i will pull the head and cut it for a squish of about .045 - .050 and then see ow that runs.
  • Third-Reef
Posted April 15, 2011 - 03:03 PM
Update on the 97 with the new top end. After one heat cycle and with the motor still warm i got 190 PSI.
  • wht02cr125r
Posted April 15, 2011 - 05:56 PM
ok so i checked my compression, it came to 195 cold, i havent tried it warm yet. the bike supposedly had less than 20 hours on it, but im just glad the top end is looking good.
07 CR250 forks by sandy250
  • 10 replies
2006 cr 85 running bad/ sputtering by Honda2smokerider23
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • 0 replies
Modern bike quality? by cr-dude3
  • 11 replies
CR125 Throttle Cable? by Will I Am
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • 3 replies
What would you honestly pay? by crdude
  • Hot  30 replies
