So my bike has always been hard to start since I've owned it. PO told me to always give it 3 pumps of the throttle when starting for the first time and kick until it starts. That worked but I am tired of kicking this thing over 30 times and never know if it will start. Now I can't even get it to fire. Has good spark and I had the carb completely apart and cleaned. Checked and adjusted the exhaust valves. Intakes were fine. Timing is right on. Don't know what else to try
. I can't even push start it because it has a
Rekluse clutch
Here is what I have:
The bike is a 04 KX250F and here is what I know from the PO:
**Motor**
2004 crank cases
290cc
Athena big bore kit
stock 2006 honda crf 250f rod
2006 kx250f crank stroked 59mm
possible aftermarket pipe (not sure what it is though, no label on it)
** Jetting**
Starter Jet 68
Pilot Jet 48
Main Jet 185
Leak Jet 60
Any ideas????????
