What is the best jetting for a 2007 Yamaha WR450F?
4 replies to this topic
  • WRF Woods Weapon
Posted April 05, 2011 - 10:21 AM
TT memebers, I have read a LOT of info here on jetting the WR450.
I have gone though a LOT of searches as well. So I need some help from those that know.
I Bought the FMF 4.1 exhaust
Also Bought the GYTR AIS kit,
I live in Georgetown Guyana ( neighbor to Brazil) 3 feet' Elevation, what should be my settings be with this elevation? i ride mainly along the coastline
Pilot: ?
Main: ?
Needle: ?
Air Jet: ?
Leak Jet: ?
Fuel Screw: ?
Throttle stop: Short Screw.
  • William1
Posted April 05, 2011 - 11:50 AM
There is no one jetting that is right for you. You start with wht is in the bike and adjust from there, resolving issues.
Fuel Screw/Pilot Jet
Fuel screw settings in the 'book' are recommended starting points. Every bike is different, as is the temp and altitude. Set the screw according to this method. Do it with the bike fully heated up.
Gently turn the screw all the way in. Now back it out two turns. Start the bike and fully warm it up, go for a 10 minute ride. Set the idle to speed to 1,500~1,800 RPM as best you can (I know, without a tach this is tough, just set it to were it idles relatively smoothly). Once warmed, slow the idle to the lowest possible speed.
*** When turning the fuel screw, keep an accurate 'count' of the amount you are turning it and record it in case you have to reset it for some reason. Makes life easier when you can just set it from notes Vs. going through the procedure again.***
Turn the screw in until the idle becomes rough or the bike stalls.
if it stalled, open the screw about 1/4 more turn. Restart it and slowly screw it in till you can just perceive a change.
If the screw can be turned all the way in and the bike still idles perfectly and does not stall, then you need to go down a size in pilot jet.
Now very slowly, open the fuel screw till the idle is smooth. Blip the throttle, let the bike return to an idle, wait say ten seconds. Confirm it is the same smooth idle.
If the screw has to be opened more than 3 turns to get a smooth idle, you need to go up a size in pilot jet.
If you find it does not stall with the larger jet but has to be open more than three turns with the smaller pilot jet, put the larger one in and set the fuel screw at 1/2 turn.
If the idle speed increased, adjust the idle speed knob to return the bike to a real slow idle speed. You must then re-visit the fuel screw. Keep doing this till the fuel screw is opened just enough to provide a nice steady idle at the lowest possible RPM. Once this is done, increase the idle speed to the normal one for your bike, typically about 1,800 rpm, but go by the spec in your manual.
Be sure to keep notes of your settings. You may find you need to make a change, say if you're riding in the mountains or down at the beach. Returning home, it is a simple matter of referring to your notes to restore things.
Main Jet
Starting with the recommended main, remove the airbox door and go for a ride (bike fully warmed up, 3rd or fourth gear, up a slight hill). Is it better or worse?
If it is better, you need a smaller main.
Go down one size, replace the airbox door, ride. Remove the airbox door and test again. Better or worse? If better, go down a size again. Keep repeating this till the test with the airbox door is worse.
If it was worse with the airbox door removed, tape over 1/3 of your airbox opening, test (airbox door on, of course).
If it is worse now with the tape and was worse with the airbox door off, your main is just right. You are done!
If it seems better, you need to go up a size in main jet. Then test it again (remove the tape). Replace the tape, test again. If with the tape on it is better, go up another size in main. Keep repeating this till having the tape on is worse than with it off.
To finish up and ensure you are set accurately, retest the bike with the tape off (airbox door on), ride it, then remove the airbox door (tape off, of course). Best performance should be with the airbox untapped, airbox door on.
Remember, the main only operates at WOT. Ideally, you want to be in 3rd or 4th gear doing the tests, hitting max revs (just shy of the limiter) for at least 10 seconds to get an accurate representation of the jet status.
The Needle:
First, confirm your TPS is adjusted correctly per the manual.
To do this, you need to mark the throttle grip. I place tape on the grip and a piece on the throttle housing. I make a mark on each. I open the throttle completely and then make a mark to correspond to that. Then I make a series of marks at 1/2, 1/4, 3/4, 1/8,3/8, 5/8 and 7/8.
Again, in third/fourth gear ride up an stead incline each time at one of the positions, make notes on how it runs at each.
If there are running issues in the first 1/4 throttle, you will need to try a different needle, one where the last letter is different. As you go up in the alphabet, you go leaner.
If there are running issues above 1/4 throttle, that deals with needle taper, length and clip position. Often just moving the clip will sort things. If a different needle is needed (say you ran out of positions) the second to last letter is what is changed. A letter is typically equal to a clip position, so an one letter change is like moving the clip on spot.
Remember, dry sounding or flat (not a bog, just flat/lack of power) is lean. Wet, misfires, heavy is rich
  • William1
Setting up the AP
The carb on your bike is a sophisticated, well engineered device. It breaks down the various requirements and controls them with 'circuits'. You have the following circuits:
Idle
Choke (actually an enricher)
Needle
Hot Start
Main
AP (Accelerator Pump)
On a thumper, it takes a breath in, digests it and spits it out and repeats. Your bike is a very high performance machine, capable of running between 1,800 rpm and 12,000 rpm. To be able to accommodate the high rpm, the carb has to be large enough to easily inhale. The carb has to also suck in fuel, it does this by using Bernoulli's Principle (wish you had paid attention now, don't you). The rushing air thorough the venturi (the carb throat) causes an negative pressure, which sucks fuel up past the needle.
But you decide to roost someone and nail the throttle. The engine is still taking little breathes but no the slide is suddenly up. The venturi is now much larger and the air velocity plummets. As everyone knows, if the air velocity drops, the negative pressure at the venturi drops. It cannot suck any fuel up the needle emulsion tube. The bike bogs, the person your were going to roost, passes you, filling your mouth with mud.
To deal with this, a pump was added, much like a squirt gun. It's job is to add enough fuel to compensate for the vacuum loss at the venturi, but just enough. It has to begin to squirt only when the throttle is rapidly opened.
There are four main parts of the AP system.
The Diaphragm
The Spring and the Link
The Leak Jet
The Timing Screw
Almost all bikes these days use the MX variant of the FCR carb and that is the one we will discuss. If you are unsure of which one your bike has,it is easy to tell. If you look at the right side of the carb, is all the Rube Goldberg parts inside or outside of the carb? Inside means it is the MX variant.Every year, the carb has gotten a little more refined and the tweaks get easier.
First, ensure you have a strong squirt. Wearing safety glasses, fuel in the tank, airboot removed, looking in the carb throat, engine off, nail the throttle. You should get a very strong super soaker stream. If not, you need to service the AP before proceeding
These days, nothing has to be done regarding the Diaphragm except replace it if it is damaged. One down.
The spring and the link are easy to deal with. You can get a stiffer AP spring (Merge Racing sells it for about $16) or you can oring the link. The replacement spring is a one time deal, the oring, needs to be replaced from time to time. To install the spring, you really have to pull the carb. The oring, can easily be installed on the bike. Orings cost about $.20 each (#78 in the plumbing section at Lowes). Some wire the links together. Wiring lasts forever, costs about $.03 however, you must ensure there is no bind at WOT or you are going to be replacing that black plastic cam. Some grind the rivet on the Diaphragm and test, grind and test until there is no bind. I have had orings last several years. To each their own. Two down
Now that you have removed the slop from the system, it is time to select a leak jet. A leak jet does just what it sounds like, it 'leaks' fuel out of the AP chamber back into the bowl. The is is what controls the sensitivity and volume of the AP squirt. There is no one size. What leak jet you use depends on how, where and how well you ride your bike. The stock leak jets were selected for "A" racers, those guys that never drop below 7,000 rpm and do cross ups between trees in the woods at 40 mph. Almost all of us are not that fast nor that good. So we need more from the AP. We need it to respond sooner and with more fuel. To do that, we put in a smaller leak jet. But we do not want too small a jet as that will waste fuel and can make jetting difficult if the AP squirts every time your hand pulses because of your heartbeat. What we want is the largest leak jet that will not cause a bog for the type of riding you do.
So.... I recommend starting out with a small leak jet, then increasing in size until the bog returns. Sadly, this can be a pain to do as the float bowl must be removed to swap the jet unless you get an AP cover that has an adjustable leak jet built in. These are pricey, from $125.00 to close to $200. For most riders, these are a waste of money unless you want carb jewelery (they come with stickers), for some that do jet for the day's ride, they are terrific as you can make an adjustment in seconds, just like with a fuel screw. For everyone else, I suggest install a #40 Leak jet if you do a lot of slow single track and are not an aggressive rider (be honest). If you tend to run fire roads or the desert and/or are a faster rider, a #55 or #60 may be a better starting point. Again, once the bog is gone, re-visit the Leak jet selection and try a leaner one. Three down
The AP timing screw. This controls when the squirt starts in relation to the slide position. We want the squirt to shoot down the slide, not slap it in the face nor do we want it to squirt on Thursday when we crack the throttle on Tuesday. In your manual, there are instructions how to set it. Most of these entail slipping a drill blank of a certain size in under the slide and adjusting the screw to have zero or a certain amount of clearance to the black plastic cam. This should be checked and set, if needed. This will be the initial adjustment point. 99.9% of the time, the squirt occurs a little late. Get your bike fully heated up at your riding place. Test ride. If you still have a bog, turn the AP timing screw in (CCW) 1/2 of a turn and test again by riding normally. Do not force a bog. I can make any carb bog if I want to. Do not test revving the bike in your garage. Test it by normal riding. At most, you will have to turn it 2 turns. Often none to 1/2 is plenty. Four down!
Now that the bog is gone, re-visit the Leak Jet and try a larger one. If the bog returns, you can adjust the Timing screw again but you do not want to turn it more than 2 turns from the initial factory setting.
  • WRF Woods Weapon
Posted April 05, 2011 - 12:17 PM
williams1..thanks dude i will have to go over every detail like you have advised..carefully and give you a feedback. they info you have supplied would definitely take some water to digest you are like a bike guru dude!!!
  • miweber929
Posted April 06, 2011 - 04:20 AM
Have you read the stickies? I am positive he lifted every sentence of his replies from his sticky posts at the top fully explaining jetting. You will also find several jetting starting point and a jetting chart up there as well.
And yes, Wiiliam is a bike guru dude. Listen to the the master.......
Mike
