How durable are Lifan engines?
16 replies to this topic
  • Nutwagonfromhell
Posted April 04, 2011 - 11:36 AM
I put a Lifan 125cc engine on my 1974 Honda XL70, I recently bought a used honda carb that looked like my original. I put my jets into it and for some reason it`s has twice the power now. I dont have enough road in my nieghborhood streets to top it out but I was around highway speed today.
What is the maximum rpm`s the engine can take?
I`m exceeding the factory specs.
It gets like 2 miles per gallon now lol.
It`s freaking scarey.
  • turbotike
Posted April 04, 2011 - 11:39 AM
"it`s has twice the power now" maby cus its a 125 in a 70 frame
  • Gotlabs
Posted April 04, 2011 - 11:41 AM
I've got one in a atc70 and it's been fine. I don't wring it out though, but it has lots of tq and the 4spd is sweet.
  • KcDavis
Posted April 04, 2011 - 11:42 AM
Impressive...I'm surprised more people don't have these so they can hit highway speeds in their neighborhood. :cheers:
  • Nutwagonfromhell
Posted April 04, 2011 - 11:45 AM
When I said twice the power, I meant from the carb switch.
I wanna find a Kikker 5150 frame for it.
I think my transmission is going out. I got it from a crappy company, and when I installed it I noticed the Transmission output shaft seal was chewed up.
  • wlfdgs
Posted April 04, 2011 - 01:51 PM
The engines are very reliable, how ever the assembly line isn't- locktite and torque specs are frequently missing. It's a 50/50 crap shoot on whether any given engine (or bike) was assembled correctly. The recommended way to make a Lifan last is to take it apart and re- assemble it making sure everything is tightened down properly.
There a quite a few Lifan forums out there and this seems to be the one constant on all of them- good engines, just bad production line workers.
  • Nutwagonfromhell
Posted April 04, 2011 - 05:18 PM
I should have bought it from HooperImports.com
The problem now is my transmission seems to be going out, when I down shift from 3rd it goes into neutral and I have to upshift then down shift again.
Can you point me to a lifan forum? Hooper imports wont answer my emails, when I ask for tech info.
  • Hugemoth
Posted April 04, 2011 - 06:59 PM
Lifan engines in general are pretty durable but it sounds like yours has been abused. Time to pull the transmission apart and see what's going on. I own 3 of them. The 200 has over 24,000 miles with zero problems.
  • Wild Alaskan
Posted April 04, 2011 - 07:00 PM
chinariders.net
  • Nutwagonfromhell
Posted April 04, 2011 - 07:19 PM
Yea I do run it hard though. The gear ratios kinda suck. First gear it does like 3 or 4 mph. it hits high rpm`s on all the gears pretty quick.
Do they make different sized gears for these transmissions. this engine was in sketchy shape they day I got it. The were even nice enough to drop it off upside down in the box on my porch lol.
I`m trying for high speed, it has enough torque.
  • Hugemoth
Posted April 05, 2011 - 10:18 AM
Best you can do is change the sprocket sizes to whatever is optimum for your use. A single tooth larger on the front sprocket can make a big difference. Horizontal Lifan engines do have a very low 1st gear. My theory is they're made for everyday transportation on small motorcycles and designed to start off in second gear using first as a granny gear for steep low speed hills with heavy loads.
  • rockraven00
Posted April 05, 2011 - 10:35 AM
I hope this helps and not hijacks....
What size chain does the 200 have?
If you put a bigger cs sprocket on it, what size chain would then be best?
Is there a beefier chain you could put on it that is still on the cheap side?
oops just seen op has a 125 and I guess being on a honda makes a difference also..
  • Wild Alaskan
Posted April 05, 2011 - 10:49 AM
the lifan engines use a 428 chain size even for the 200
  • Nutwagonfromhell
Posted April 06, 2011 - 05:28 PM
Mine is a 420 chain. It seems to be up to snuff now. I just need tires and get the brakes working.
I was wpnder if a new honda xr100 gears could fit in the lifan engine? I`m going to rebuild the original 72cc engine once I get the monet, but even that had short gear ratios.
  • brapbrapbrap
Posted October 07, 2013 - 07:55 PM
What was the Honda carb off, I'd been keen to do this to mine :)
  • choppertown
Posted October 07, 2013 - 08:13 PM
i had one. beat the piss out of it. keeped it pined to the tits all the time. broke the frame. it sat outside for 2 years. water got into it somehow. hydro locked. rings rusted shut. drained the water and oil. put new oil in. sprayed 1/4 of a bottle of wd-40 into the cylinder. let it sit...kicked it over, got most of the oil out. kicke dit over till it started. cranked on it..the rings came loose....
now its in a buddies go-kart and still going. being reamed out even worse.
id say they are pretty indestructible.
HOWEVER, i did take it apart and locktight the hole motor and torque everything down the day i got it.
  • T Bolt USA
Posted October 26, 2013 - 07:26 PM
The horizontal Pit bike type engines work very well , 17T front sprocket helps make 1st gear more usable
