2008 yz 450f pilot jet change
9 replies to this topic
  • lanny574
Posted April 01, 2011 - 07:57 AM
does anyone know of an easier way to change the pilot jet out, without having to take ther carb out?
Posted April 01, 2011 - 08:11 AM
Do you know why it says, "look here first" on the Common Threads Sticky? :cheers:
http://www.thumperta...ad.php?t=556427
Motion Pro makes a ready-made for the purpose screwdriver, but the paper clip trick is still unbeatable.
A 2" inspection mirror is also helpful. :ride:
  • SXP
Posted April 01, 2011 - 11:03 AM
I find laying the bike on it's right side also makes the process easier. I envy your lack of a starter (in this ONE instance only:smirk:), as it does open up some more room to work with.
  • yzf1999
Posted April 01, 2011 - 04:03 PM
loosen the carb boots, rotate the carb as much as possiable and drop the float bowl (4 allen bolts)....thats how i did mine
  • idahoexcr500
Posted April 02, 2011 - 03:01 PM
I also removed the seat, tank and top motor mounts to allow the carb to rotate a little further. not that much more work.
  • SXP
Posted April 02, 2011 - 04:47 PM
Not easy anymore.....
  • Family Man
Posted April 02, 2011 - 04:48 PM
yeah no special tools needed.
  • dvn
Posted April 02, 2011 - 05:23 PM
I used the paper clip method on my daughter's YZ250F today. Worked like a charm! :cheers:
  • ttr250dude
Posted April 03, 2011 - 03:20 AM
It's all just nuts and bolts. Nothing complicated.. When i was in 5th grade i took off all my plastics and my seat just for fun. You wont learn until you try :cheers:
  • SXP
Posted April 03, 2011 - 09:50 AM
Something was lost in translation......
I was commenting on the post of the person who I quoted. His method made it more complicated (IMO) then it needed to be. Hence the "it's not easy anymore" comment.
Motocross
  • Hot  491 replies
  • 9 replies
  • Hot  36 replies
  • 10 replies
