Ok here is the deal, Simple rebuild, something that I have done over and over and over again. Followed the book to the "t" with making sure everything is set correctly, TDC, everything, Checked clearences, all within spec. Checked crank, everything good there. Installed new piston and rings, made sure rings were at their proper position on piston.
Once piston installed, started to put the bike back together. Followed the instructions for the timing, all marks line up properly with the appropriate amount of pins between marks, cams installed at TDC, checked clearences again. Everything matches up to what it was before the rebuild. Go to start it and it wont start. The occasional back fire, but nothing at all. Doesn't feel like it has much compression however I ride 450's and to me nothing feels like it has compression compared to those. Have fuel, have spark, All wires checked and recheck... Still will not fire...
Any ideas?
