2006 KTM 250 SXF - Kickstart Shaft Replacement
5 replies to this topic
  • rickcarte
Posted March 29, 2011 - 05:40 PM
The grooves/splines on my kickstart shaft are stripped out. I think it is time to replace the kickstart shaft. Does anyone know where I can get a repair manual? Does anyone know how to replace the kickstart shaft?
Thanks,
Rick
  • Mike in Fresno
Posted March 29, 2011 - 07:16 PM
thats an easy fix, just take off the right side to access it...as I type Im thinking it may require removing the clutch hub tho, cant remember for sure, sorry
  • rickcarte
Posted March 30, 2011 - 04:36 PM
I have ordered a new kickstart shaft, kickstart lever, and kickstart shaft seal. I guess I will just start unbolting the right side near the shaft and see what it looks like underneath. I hope it is an easy fix.
Thanks,
  • speedboot
Posted March 30, 2011 - 10:20 PM
first remove the waterpump cover and cirlip an impelor and steel drive pin. . remove all site cover bolts and pull the cover of the engine , dond,t let the waterpomp shaft come out of the engine when you pull of the cover . . best thing to do is set the engine in tdc with the timming marks on the cams sign together. when the shaft come out you have to time it again,so hold it in place in the engine. .
  • Dave Hopkins
Posted March 31, 2011 - 11:09 AM
Can't over emphasize what speed said about the WP shaft, I hold it down with my thumb while pulling on the cover
Once the cover is off Kstart lifts out easy but as you put it together there is a center punch mark on the gear that goes in first that MUST be in alinement with the spring hole drilled into the shaft, if not in aline the starter will engage at the wrong point
  • rickcarte
Posted March 31, 2011 - 02:53 PM
Thanks for the help. Next Monday is when i expect delivery of the shat. I may have more specific questions then.
2016 xcf 250 or 350? by Vettev
  • Hot  26 replies
Unreliable Starting by Rageodontist
  • 4 replies
Transmission swap? by jake101
KTM's new enduro chassis has NO LINKAGE by Johnny Depp
Dirt Bike   Make / Model Specific   Beta
  • Hot  66 replies
SXF 350 big bore kit by Steve_Kay
  • Hot  31 replies
