2002 WR 426 gray wire location
2 replies to this topic
  • cz9mm
Posted March 26, 2011 - 12:05 PM
I can't find the gray wire as described in other posts. The only gray wire is in a 2 wire connector.
  • dustdogg
Posted March 26, 2011 - 05:06 PM
Check this out. Its for the 250 but yours is the same.
http://www.thumperfa..../gray_wire.htm
  • cz9mm
Posted March 27, 2011 - 01:26 PM
Thanks for the link that made it very easy. I thought some where someone said the 6 wire connector but that image was very clear. Tried the mod amd didn't really see any difference but I don't know what else was done to the bike. The guy that had iot before me removed the throttle stop screw totally and I modified a screw and installed so it is the same as a yz. I think that is what was making the bike break up so bad on the top end. Now the problem is not as bad after installing the screw.
